Results 11 to 19 of 19
- Jul 2011
- 78
- Feb 2019
- 58
May 16th, 2019 08:48 AM #12check it out. See if the lights are still on after replacing the battery. If not, perhaps it is your alternator which is acting up.
Audacity Find My iPhone Origin
- Jul 2011
- 78
July 1st, 2019 11:52 AM #13Update.
Lights came on again after just leaving the car parked outside. Will try to charge again the battery to see if it will go away again. Would like to inquire if anybody can recommend a shop in Paranaque area which has the device to read the sensors just in case the battery charging won't work.
Many thanks.
- Jan 2008
- 4,726
July 1st, 2019 11:57 AM #14
- 52,731
July 1st, 2019 11:59 AM #15
- Sep 2018
- 77
July 1st, 2019 01:03 PM #16What you can do is to have the alternator checked and see if the battery cables are tight. However, if you need further assistance, you can visit your trusted car shop. Also, You might want to visit this website online. For sure they have a listing for the best shops within Parañaque that would cater any of your car related needs. Hope you'll find this helpful
- May 2017
- 2,099
July 1st, 2019 05:05 PM #17
So hindi battery ang problema? Ilang years na ba ang sasakyan mo?
1.) There could be a problem with your alternator.
2.) If the alternator is ok, then there could be a parasitic drain in your electronic systems.
Use a multimeter/multitester to test if there is power going to your car battery from the alternator
- Jul 2011
- 78
July 3rd, 2019 12:43 PM #18
- 52,731
July 4th, 2019 01:24 AM #19
IIRC they're with AVID. The reported numbers in the TG article are from CAMPI.
Car Sales Data (2024)
