Results 11 to 15 of 15
August 3rd, 2016 05:58 PM #11
If there was a short circuit it James Brown I feel good - YouTube blow the fuse but your BAT terminal circuit to the starter does not have a fuse but sure will get the cable hot. If your car has manual transmission, place the transaxle in fourth gear, release the parking brakes and nudge the car back and forth to see if the ending turns. If it does not turn, he engine might have locked up, or the engine went into hydro lock.
- Oct 2013
- 2,537
August 4th, 2016 01:06 PM #12
- Aug 2003
- 9,720
August 4th, 2016 01:11 PM #13
- 52,698
August 4th, 2016 01:41 PM #14still hasn't started?
remove the air cleaner,and pour a tansan-ful of gasoline into the carburetor's throat.
then try starting it several times.
also, test the carb solenoids. baka may nasunog.Last edited by dr. d; August 4th, 2016 at 01:53 PM.
August 5th, 2016 05:39 AM #15
The fuel pump runs on two modes
1 start mode------ the fuel pump runs on default 3-5 seconds to pressurise the fuel rail for faster start up
2 run mode------when the engine e starts, the ignition signals from the crank sensor and the cam sensor enables the PCM to command the fuel pump relay to run the fuel pump.
The fuel pump did not run the battery down.
toyota fuel pump control circuit - Google SearchLast edited by jick.cejoco; August 5th, 2016 at 05:45 AM.
Latest mileage:
