Results 1 to 8 of 8
- Nov 2002
- 51
November 25th, 2002 09:08 PM #1Sir Gurus,
Ang '93 Feroza po namin ay napansing ko pong mapalag lamang at 1,800 rpm. Above at below this ay ok naman. Bakit po kaya? Ano solusyon?
Salamat po. :?: :roll:
- Nov 2002
- 51
November 27th, 2002 08:45 AM #3
Check mo things that are attached to your engine, alternator, AC compressor, power steering pump, engine mounts/supports. Baka may loose screw or maluwag na turnilyo (translation:mrgreen. Nag re-resonate siya sa 1800rpm.
- 238
November 28th, 2002 04:09 PM #4Because Ferozas were actually built for offroad use in mind, gearing is low. They have a final drive gear ratio of 5.29. FYI - my Hilux 4x4 when stock had only 4.56, I had to regear to 5.29 to accomodate the 35" tires. You'll notice that your Feroza accelerates fast, is superior climbing uphill and a very capable tow vehicle, but you have to rev up higher.
With low gearing and small diameter tires your power band width begins at about 2000 rpm upwards. Meaning your hp and torque are at its best in this rpm level.
Solution : Match the tires to your gearing. Use 31" or 32" diameter tires. You will have to lift your vehicle 1 to 2 inches. Do this by cranking your torsion bars, and extending your rear leaf spring shackles by 1 to 2 inches.
With this tire upgrade, your power band should be in the 1,000 rpm range.
Happy trails!
BTW - The Feroza is one underrated 4x4. But it is actually more superior than most, beleive you me!
November 29th, 2002 08:50 AM #5Originally Posted by Freeman
November 30th, 2002 12:55 PM #6
Kung hindi lang talaga masakit sa likod ang suspension ng Feroza, I might be driving one today.
5.29 na pala gears niya. Ayos, yan. Hehehe. Lakas ng low-end grunt.
December 3rd, 2002 06:30 PM #7
........ok yung Feroza kaya lang diffiul finding piyesa. "FARUZA" daw sabi ng isang owner na nakausp ko :D
- Feb 2008
- 19
April 3rd, 2008 04:05 PM #8
