Results 1 to 4 of 4
- Apr 2011
- 10
July 7th, 2011 05:11 PM #1Hi Optra owners,
just wanna know kung saan ko pwede ipagawa tong mga things na to sa optra 1.6 LS ko na manual:
- key less entry feature
wala na ata battery ung sa susi ko, d na kasi bumubukas pag pinipindot ko ung lock/unlock.
- master lock on windows
sumasablay minsan ung power lock ko sa drivers side na window.
- odometer and speedometer.
bigla nalang d gumagana ung Odomter and Speedometer ko.
- signal light switch
ung switch ko (ung sa may steering wheel), sumasablay rin minsan.
your infos will highly be appreciated. also, if you can provide kung magkano aabutin sa pagpapagawa ng mga problema ng baby ko as of now, i will be very very very much thankful.
thanks,
Mythoptra
- Jun 2011
- 251
July 7th, 2011 07:46 PM #2boss yung sa keyless nya malalaman mo yan pag ayaw ng umilaw nung indicator sa susi mo yung maliit na lead light sa dulo na pula, pag ayaw means wala ng battery,...
master switch sa windows sir pano bo ba sumasablay po?
yung sa odometer naman po pareho kasing sender module sila baka sakaling ma natangal lang or yung likod na sensor mismo ng guage yung problema. may napunta sa shop sati same problem sabi nya (spark) 1k lang daw yun na order nya. i dont know where.
sa signal switch yun ang di ko alam hehehe baka sakaling switch relay lang or fuses (sana.)
ano po ba pinagawa ng huli nyo po?
try nyo rin reset yung box 30 sec. on 30 sec. off 5 times.
yung sa power lock nya baka kaya pa i pa reset yan sa casa mura lang ata yan.
hope na nakatulong kami...
- Jul 2007
- 83
July 8th, 2011 12:16 PM #3Do you still have the manual for the Optra?
The instructions on replacing the battery in the key is there. If you don't it's as simple as removing one screw. Opening the housing, and replacing the battery with a similar one. Take note though on how the battery is placed into the key.
What do you mean, "sumasablay minsan ung power lock ko sa drivers side na window."
Signal light switch? Combo switch ito. What problems are you encountering with it? Is it the switch or the Flasher? Please describe it in detail. Signal lights light up? Indicator sa instrument panel lights up? or basta walang ilaw at tunog?
Odo/Speedo - better bring it to the casa to check for the DTC (Diagnostic Trouble Codes) This one needs a Scan Tool.
- Apr 2011
- 10
August 31st, 2011 04:39 PM #4sir ppcsurfr,
thanks for this reply.
actually ung combo switch, napansin ko lang, kapagka binago ko ung tilt ng steering wheel, ok na ulet. i mean, d na sumasablay.
describing it in detail:
pag sumasablay ung signal light ko, may 'clicking' sound lang ako naririnig. ung flasher namn, totally d na talga siya gumagana..
ung about sa odo/speedometer ko, pag magpapa DTC po ako ng chevy, magkano po bayad? meron po ba?
thanks again sir.
god bless.
any feedback for America Lumina Nano Ceramic ? which better between Sunblock Ceramic vs Lumina...
