Results 1 to 10 of 10
- Jun 2010
- 23
October 13th, 2010 11:13 PM #1i've noticed this twice already.
nung una bumaha pero was able to pass it. a day after that napansin medyo mahirap na ikabig. nagpa under wash ako then medyo naging okay na. after that di ko na napansin.
then the other day bumaha ulit, tapos this time mas grabe. pag todo kabig ka pag atras then sabay release ng kamay para bawi sa kabilang side, hindi nangyayari yung usual release na counter doon sa unang ikot mo sa steering wheel. kahit yung simpleng kunting kabig lang para slight adjustment during driving eh wala.
hindi naman ganun kataas ng baha kasi i was able to pass through.
meron nga ako nabasa dito, na ondoy yung optra niya pero one of the things he mentioned na okay pa sa optra niya is yung power steering.
1. saan ba located yung wiring para sa power steering?
2. sabi ng friend ko mukhang kulang ng hangin yung both tires sa harap. so those things i mentioned above sa second paragraph, mangyayari ba mga yun pag kulang sa hangin ang tires sa front?
October 13th, 2010 11:28 PM #2
wiring? ang pag kakaalam ko ang power steering ay purely hydraulic walang electrically controlled ito,
- Jun 2010
- 23
- Mar 2009
- 100
October 14th, 2010 12:15 PM #4na-check mo na ba yung steering fluid? baka ala na fluids.
+ baka palitin na yung set mo rack-end... check mo din yung
mismong naikot na gear (yung parang differential), baka sira na
yung takip na goma at tuyo na, me special gear oil yun.
- May 2006
- 33
- Jun 2010
- 23
October 14th, 2010 01:00 PM #6yup, that was the first thing i did. checked the fluid at puno pa, so leak is not the problem. then sa net hinanap ko ano usually causes sa ps problem. nakita ko is basa ang belt. so tinrace ko ang front at back line galing sa ps fluid compartment, kita ko sa taas naman nakalagay ang belt so di abot ang baha dun.
then sa kakatrace ko sa line, nakita ko yung takip hose na black na parang spring ang style na butas na nga. this was before you posted your reply.
your post confirms ang hinala ko na this has got to do with the problem. kasi yun nasa baba at likely na submerge sa baha.
thanks.
- Jun 2010
- 23
- Jun 2010
- 23
October 14th, 2010 01:18 PM #8*dndk,
any idea kano gagastosin ko sa hose at special oil na yan?at kung kelangan yung mga mechanic na may specialty ipagawa to or kaya na to ng mga mekaniko na madiskarte? hehe.
- Mar 2009
- 100
October 16th, 2010 11:17 AM #10mahal yan kung papalitan mo kase set yan... what i did sa sakin was from time to time im checking yung butas na goma (parang spring) and nilalagyan ko nalang ng lubricant oil to keep it smooth. otherwise ang tigas ng handling ko sa manibela.
pa inspect mo rin yung ilalim ng mga front wheel mo, rack end set + yung dun sa me parang goma na spring ulit ng mga front wheel, baka me tagas na.
Monk-owned R53
