Results 1 to 4 of 4
August 14th, 2011 02:18 AM #1
My 06' Optra is having trouble on its acceleration.
I recently change the spark plug ( Bosch 2 pin) not the OEM 1 pin NJK
and also changed the air filter and fuel filter but the problem stil persist.
1st to 5th gear its jerking. Need help
My car is just always in the garage coz i am always out of the country.
Thanks
- Jul 2007
- 83
August 14th, 2011 08:09 AM #23 down and 97 to go...
But seriously, those three are not always the cause of jerking.
You can break this down to two possible groups. The ignition system and the fuel system.
You said you're always out of the country, so I'll go out on a limb here and say that you probably have shellacked throttle body and injectors that need cleaning.
Of course having your car diagnosed at the dealership will give you a better insight of what is wrong with your car.
And if they suggest that you change your fuel pump, ask them for the fuel pressure reading. If they can't tell you what the pressure is, then they're just guessing. The service manual states that the fuel pump pressure should be within 284~325 kPa (41~47psi).
- Jun 2011
- 251
September 2nd, 2011 12:43 PM #3di po ba mababa yung clutch mo boss...
namamatay po ba?
every gear po ba ay kumakadyot?
pag naka rekta boss ok naman ang takbo?
pag nilagay sa neutral ok naman po ba ang menor?
ano po huling pinagawa boss?
September 2nd, 2011 11:10 PM #4
Problem solved pinacheck ko sa kuya ko sa goodyear alabang pinatingnan ko sa computer diagnosis ba yun
nakita sira n yung spark plug wires. ayun kya pla jerk ng jerk. 2 wire n lang ngana. nagtataka ako kasi 96,000km pa dapat papaliptan eh 50,000km p lang ako. bkit prang ang bilis? lagi kasi asa bhay lang yuns sskyan di kya yun.
Maraming salamat sa replies!
galing nun sa pressure my psi pala yun my natutunan n nmn ako!
Wala parin spare tyre?
2025 Nissan Kicks
