Results 1 to 7 of 7
- Dec 2010
- 18
August 2nd, 2011 08:33 PM #1Guys may noise kasi sa likod ko na ang tunog yung parang "pinipipi" na coke in can. Naririnig ko to pag sinasampa ko sa malaking humps, or sa gutter pag nagpapark yung cruze. Minsan sa mga bumpy roads naririnig ko din. Pinacheck ko na sa pasig branch at sa alabang parehas wala silang nakitang mali kasi hindi nila matyempuhan pagnagtetest drive sila. Ano kaya advise niyo sakin.. hanggang ngaun andun padin yung noise. Chineck ko baka may nahulog lang sa upuan, wala naman o kaya sa compartment tinanggal ko na lahat andun pa din yung noise. sa suspension talaga nanggaling kasi pati sa labas ng cruze rinig yung noise. Pahelp naman tnx.
August 3rd, 2011 12:24 AM #2
Is this the knocking sound po? It might be the brake caliper kit. I had the problem whet my cruze was at 2000kms ODO. Try suggesting it to your dealer.
- Dec 2010
- 18
August 3rd, 2011 02:29 PM #3naiinstall na yung brake caliper kit before yung noise. regarding kasi sa brake caliper kit, yung ugong na tunog parnagrereverse ang kino-correct.
August 4th, 2011 01:32 AM #4
Yung brake damper yung nagtatanggal ng noise pag reverse. Pero yung knocking sound sa
Humps or any pothole, sa caliper kit ng brake. Baka kelangan ng teflon lining or grease. Mejo sakit ata ng mga american at euro cars yun. Nabasa ko lang sa isang article.
- Dec 2010
- 18
August 8th, 2011 02:55 PM #6
- Dec 2010
- 18
September 20th, 2011 04:29 PM #7I brought my car in Chevy Pasig last week and the mech removed my brake caliper pin. Nilagyan lang niya ng grease at sabi niya nagloloose daw yun kya nagkakanoise, if may ingay pa din ibalik ko lang daw tapos babalutan daw niya ng teflon tape para sumikip. Well andun pa din ang noise kaya plan ko siya ibalik bukas. I've done some research and this is not an isolated case. Its also experienced by other cruze owners around the world, only the position of the suspension is different. Probably cause is a loose brake caliper pin or a misaligned/"out of place" insulators for the spring (Top and bottom). I will ask them to check these both and see if it would fix this problem.
I hope those cruze owners na nakaka-experience din ng same problem won't hesitate na maginquire sa Dealers nila or sana magfeedback sa post ko kasi tinitreat ito na isang isolated case which they don't take seriously. I like my car that's why anything unusual I will immediately check and take it to casa for checking. I'm already fed up of those mechanic/SA lines saying that "Ok naman po wala naman pong problema chinek na namin.." I won't waste my time, energy and fuel to take my car in the casa for no reason at all.
I hope those would read these would understand my point.
IIRC they're with AVID. The reported numbers in the TG article are from CAMPI.
Car Sales Data (2024)
