Page 11 of 16 FirstFirst ... 789101112131415 ... LastLast
Results 101 to 110 of 151
    Oct 2018
    #101
    Unfortunately, they did not inspect the car! They just based it on the mileage and they already have these items as “mandatory”. Probably they’ll just reduce then items if they still find the original ones still ok or if the customer won’t opt for the replacement. But still, daya di ba, what if the customer is not knowledgeable of what’s mandatory or not.
    Warranty will lapse in a few months time. I’ll just have the PMS done outside casa, with the exception of timing belts etc. but I’ll have it inspected anyways.
    #102
    Quote Originally Posted by RNIQQQ View Post
    Warranty will lapse in a few months time. I’m leaning towards having the PMS done outside, with the exception of timing belts etc. but I’ll have it inspected anyways.
    You can just scratch off 8-14 and have it inspected instead of replaced. Check sa manual if you need to replace #7 / drive belt for 50k.
    Which dealership is this? Medyo ripoff siya.
    Oct 2018
    #103
    Quote Originally Posted by mda View Post
    You can just scratch off 8-14 and have it inspected. Check sa manual if you need to replace #7 / drive belt for 50k.
    Makati (Pasong Tamo ext)
    Thanks for the advice!
    #104
    If they insist on replacing #8-14 without inspecting the car, lipat ka ng dealership. Again, not sure on #7 (drive belt). Please consult your manual for that one.
    Replacing the pulleys is normally done when they are worn, same with the water pump.
    Laki ng kinikita nila sa unsuspecting customers. No wonder chevy has a bad rep here. Never kami inalokan ng ganiyan for 'preventive' maintenance for our japanese vehicles...
    Sep 2014
    #105
    Hi everyone, thanks for the reply! HereÂ’s the quotation from casa for my 2014 4x2 2.8L A/T TB, current mileage is 55k km.
    IÂ’ll compare this list vs the ownerÂ’s manual but I think, this is way TOO much!
    Any recommendation for best shops I can have the job done will be greatly appreciated
    Parts & Materials TOTAL PHP52,155
    1) Engine Oil - Php4,950
    2) Oil Filter - Php1,011
    3) Brake Cleaner - Php282
    4) Air filter - Php3,360
    5) Pollen filter - php2696
    6) Engine Coolant - Php2620
    7) drive belt - Php1,848
    8) Drive belt tens. - Php7500
    9) Idler Pulley (small) - Php3,864
    10) Idler Pulley (big) - Php 5,040
    11) Idler Pulley (lower) - Php2,016
    12) Timing Belt - Php5,040
    13) Timing Belt Tens. - Php3,528
    14) Water Pump Assy. - Php8,400
    Shop Supplies - Php 500
    Labor - Php 8,280
    TOTAL PMS COST: Php 60,935!!!
    good thing I didn't get the Z71 over the blue power. timing belt pala and TBZ. always thought halos pareho lang tong dalawa.
    #106
    In the casa, if they wanted to inspect the timing belt and the drive belts, the labor costs alone will be similar to replacing them.
    For peace of mind tho, just replace the timing belt and drive belts, idler pulleys etc. Since, pag naputol sila, sira makina.
    Replace 7-13
    Take a gamble with 14.
    But ur call.
    Succeeding pms, have it done outside. Basta every 60k kms, do 7-13.
    Hold on... Check ur manual, timing belt supposed to be at 80k kms.
    Drive belts can be at 60k kms.
    If u tell them to inspect, they'll tell u, manipis na, without really inspecting. Of course ninipis vs bago, kasi ginagamit.
    #107
    in my case, done doing the all belts and pulleys/pumps at 95k ODO reading (manual says 60k or 3yrs whichever come first).
    - all parts were provided by me from Thunder Banawe except for those not available at that time (most listed parts below are much cheaper here though that was 2017). my casa is chevy dagupan under laus group (NO "corkage" fee on all parts brought in)
    - recommend to replace both belts together and its accessories to avoid double labor charge
    - there's a "SPECIAL TOOL" used by casa to achieve the factory timing setting. strongly suggest to let casa do it for you.
    - IIRC, my all belts replacement plus PMS and labor cost was around 40k only which is much lower than your casa quoted amount.
    - sa 55k ODO reading ba ang OCI PMS mo? if i were you, i'll do the all belts replacement not together with the usual 10k OCI to "lessen" the total cost.
    Labor - Php 8,280
    #108
    Every 3 years ang pulleys and pump??? Well played, Chevy. Either they know they have inferior products or they are really hurting for cash...
    #109
    I know where you're coming from coz before disposing my 12 yrs old toyota , only the drive belt and pump were replaced and my 8 yrs old honda's drive belt and accessories are still intact and good running condition.
    It'll be included on my checklist for sure on my next car purchase if ever i'll go with the golden butterfly logo again.
    Sent from my Flare_X_V2 using Tapatalk
    Oct 2018
    #110
    Thank you so much guys for sharing your thoughts here; very helpful in coming up with a sound decision wrt the “pms” my car should have this round. I’m leaning towards delaying the change belts as per owner’s manual to 60k km. I’ll have another quotation from another dealer and non-casa shop just so I have comparison, I would know where to bring the major ones. Cheers!
Chevrolet Trailblazer Maintenance...
