Results 3,821 to 3,830 of 4415
- Jul 2006
- 3,376
August 4th, 2013 06:41 PM #3821
- Oct 2010
- 11
August 4th, 2013 10:28 PM #3822Sir good day, ask ko lang po kung okay ba ung HU ng growl audio.. Bought TB po Auburn Brown from A
Alabang... Madami na po bang nagpa install ng HU Growl? Thanks
- Jul 2006
- 3,376
August 5th, 2013 12:53 AM #3823
August 5th, 2013 03:42 AM #3824
- Jul 2011
- 12
August 5th, 2013 04:35 PM #3825
- Apr 2006
- 351
August 5th, 2013 05:11 PM #3826What happened to batang pasig for a new car would always be worrysome. This can be an isolated case for the TB. Stalling, MIL (Malfunction Indicator Light) would always refer to Intake and exhaust problems. The low oil pressure indicator would lit usually because engine has stalled. Once fuel is running or the engine gets going the low pressure light will be off. OBD can check for the faults. It was noted that there was a faulty fuel pressure sensor which was probably disconnected. This i guess would be poor connector or it wasn't connected properly during assembly. Lock failure or poor contact which caused the car to stall. Hopefully this is just the case. A thorough check of course by the casa has to be done. As long as no trouble codes arise then the car would be fine. It would be nice to have an OBD 2 scanner handy. You can once in a while check for codes especially if you had your engine detailed, minsan meron natanggal na connector even when you have your regular PMS they tend to forget to lock the sensor for the MAF and when travelling it gets loose and you will have a MIL on your dash.
- Oct 2010
- 11
August 5th, 2013 08:58 PM #3827
- Oct 2010
- 11
August 6th, 2013 07:32 AM #3829
- Oct 2007
- 14
August 6th, 2013 10:34 AM #3830
Monk-owned R53
