Results 2,371 to 2,380 of 4415
- Jan 2007
- 219
January 27th, 2013 12:31 AM #2371As for my breakdown:
1. Labor 949.00
2. Parts 4041.40
3. Sundries 500.00
Total 5490.40
Oil used base mineral oil (Dexos)
Chevy North Edsa have friendly Service Advisors. Their service area seems clean, and they cleaned my TrailB in and out. Got back my TrailB in 2 hours.. Also, I requested them to install a light bulb in the right rear fog light.
- Dec 2012
- 293
January 27th, 2013 12:33 AM #2372
- Jul 2006
- 3,376
January 27th, 2013 12:37 AM #2373Hmmm, parang alam ko na saan ako magpapa PMS once umabot na ng 5k kms TrailB ko
I computed kung magkano initial PMS cost kung Dexos 2 5W-30 Fully Synthetic Oil ang ginamit based sa presyo ni *safala:
4041.90 - (240x7) = 2361.41
2361.41 + (800x7) = 7961.41
7961.41 Parts including labor
+ 949.00 Labor
+ 500.00 Sundries
9410.41 Total initial PMS costLast edited by numbah5; January 27th, 2013 at 12:48 AM.
- Dec 2012
- 293
January 27th, 2013 01:28 AM #2374
- Jul 2006
- 3,376
January 27th, 2013 02:01 AM #2375According to the manual of the Trailblazer, 5W-30 is the suitable viscosity of fully synthetic oil for the Duramax Diesel engine. And dapat Dexos 2 compliant oil ang gagamitin na fully synthetic oil. Hindi TCCCI nagsabi niyan, kundi yung mismong GM HQ na. Sila nagformulate ng Dexos 1 and 2 for the specifications of their vehicles. Kaya other oil brands had formulated Dexos 2 compliant oils, and tested them under the supervision of GM Tech people in order to be certified as Dexos 2 or Dexos 1 compliant. Dexos 2 is only 5W-30. The benefit is that every 10k kms ang oil change and balik sa casa.
Pwedemg gumamit ng ibang oil pero it should have a viscosity of 15W40 only and passed the API CI-4 or CJ-4 specification. Yun nga lang, every 5k kms ang oil change.Last edited by numbah5; January 27th, 2013 at 02:04 AM.
January 27th, 2013 08:19 AM #2376
- Dec 2012
- 293
January 27th, 2013 11:32 AM #2377
Nagpakabit ako dati sa strada ko xenon workx 12,999 sale pa 2009 until now okay parin nagpakabit ako sa sonata hi and fogs 2,500 per set Parati may prob yung ballast. Btw casa price sakin ng HID 12k sa Chevy alabang(taga much) ang consolation mo Lang sir if anything goes wrong the blame is on them
- Mar 2010
- 95
January 27th, 2013 12:45 PM #2378
- Mar 2010
- 95
January 27th, 2013 02:04 PM #2379*numbah5, there is a dexos2 compliant fully synthetic motor oil na 5W-40. For fellow owners, you can look into this link for added information:
GM dexos information center
General Motors is committed to designing, building, and selling cars that perform well and last a long time – and to making the experience of owning a GM vehicle highly rewarding. GM is also working to make its vehicles more fuel efficient and emit fewer pollutants. A critical component of performance, longevity, and environmental sensitivity is the quality of the oil that goes into the car. The right oil will help your engine run well for a longer time; substandard oil could cause your engine to run poorly and may even damage it. Yet, in today’s market it’s not always possible to determine the quality of the oil you buy.
That’s why GM Powertrain engineers developed the dexos™ engine oil specification. The result is engine oil designed specifically for your GM engine, with added performance in areas important to its operation. dexos™ represents a high quality, robust oil formulated to some of the most rigorous specifications in the industry. And just like GM, dexos™ is global. GM wants to make sure that every GM car anywhere in the world has access to the highest quality oil formulated exclusively for GM engines.
dexos™ is designed to increase fuel efficiency, extend the life of your emissions system, require fewer oil changes, and produce fewer emissions. You save time and money, and your car performs the way it was designed to.
dexos™ is the best oil for any GM car. It’s that simple.
To ensure you are using the recommemded oil for your GM car, choose authentic, licensed dexos™ oils. dexos™ is an exclusive trademark of General Motors. Only those oils displaying the green or blue dexos™ trademark and icon on the front label have been certified and licensed by GM as meeting the demanding performance requirements and stringent quality standards of the dexos™ specification. Other oils may make claims but have not gone through GM’s rigorous testing and quality control process.
Specifically designed to meet the needs of GM diesel engines*, dexos2™:
protects diesel engines from harmful soot deposits
is designed with limits on certain chemical components to prolong catalyst life and protect expensive emission reduction systems
is a robust oil, resisting degradation between oil changes and maintaining optimum performance longer
dexos2™ is also the recommended service fill oil for European gasoline engines.
* Duramax is the exception and requires lubricants meeting CJ-4.
Look on the front label for any of the logos shown above to identify an authorized, licensed dexos2™ engine oil
I hope this helps.
- Jul 2006
- 3,376
January 27th, 2013 02:34 PM #2380Yup pwede 5W-40 basta Dexos2. Pero the manual specifically said the best viscosity grade for the Duramax Diesel engine is 5W-30.
Scanned images from the manual:
