Results 2,161 to 2,170 of 4415
- Jul 2006
- 3,376
January 13th, 2013 10:00 AM #2161Don't change your V-Kool OEM 05 tint on your side and rear windows. Changing it to 3M Black Chrome is like downgrading your tints. V-Kool has high heat rejection rates. The OEM 05, which I also had installed on my TrailB's side and rear windows, has a 78% heat rejection rate, higher than 3M and solargard. What you can do is to follow what I did, install V-Kool Signature K14 tint on the front windshield. It is V-Kool's version of 3M Black Chrome. It has a 83% heat rejection but the visibility is better than OEM 05. You'll still have your privacy at the same time, no heat when you leave your TrailB under the sun for hours at the same time, maganda ang night visibility mo.
HTHLast edited by numbah5; January 13th, 2013 at 10:03 AM.
- Jul 2006
- 3,376
January 13th, 2013 01:23 PM #2163
[QUOTE=ram angle;2071696]With 50km up&down hills, 20% higher than the performance of Fortuner V.
Sa paakyat kailangan yong 2nd principle ng matic xmssn ang eapply, kc pag normal tapak lng mabilis mag up shift then medyo bitin magddown shift . Para smooth more than half ang tapak para up to 3000rpm bago mag shift. Iniwan ko navara sa ahon , great torque
- Jul 2006
- 3,376
January 13th, 2013 03:52 PM #2164Bagay na bagay bro! Off road mags will make any SUV look more macho. Tapos kahit yung Dura Grappler ng Nitto tires mo, machong macho pa rin. Go for 18s para off road look talaga. Nitto has the same tire size ng stock tires natin.
- Jul 2006
- 3,376
January 13th, 2013 04:14 PM #2165You can also go for Mickey Thompson Baja STZ and Cooper Discoverer S/T Maxx. Basta the 3 tires I mentioned are good tires
- Oct 2006
- 20
- Oct 2006
- 20
- Jul 2006
- 3,376
January 13th, 2013 06:57 PM #2168
January 13th, 2013 08:48 PM #2169
May nakasalubong akong white LTZ kahapon on my way from Antipolo. Mukang magpapabless :D
The white ones makes me drool
- Sep 2011
- 12
January 13th, 2013 10:46 PM #2170same problem here, our trailB's lift gate is useless for now, chev alabang diagnosed it and said the the culprit is a crappy harness connection. they already ordered the replacement part, but the problem is that they cannot commit with the date when the part will come in .
Cabin Air Filtre Carbon activated, interchangeable with 27277-4JA0A/B P190 only. Almost P3k ito...
Nissan Navara NP300
