Results 1 to 7 of 7
- Oct 2010
- 59
October 21st, 2010 02:21 AM #11. ok lang bang hindi na sa Casa magpa-oil change? pwede na ba sa iba like Rapide? sobrang layo kasi eh.
3. gaano kadalas dapat i-check ang tubig ng radiator?
2. anong coolant ang magandang gamitin para sa radiator?
4. may grinding sound ang brakes tuwing nasa inclined roads and surfaces. sounds like, "grrrg". it happens when the car is put on a full stop. is this normal? if not, ano kaya ang cause nito at anong pwedeng gawin para mawala yung tunog ng brakes?
sana madaming makatulong at magsabi ng comments.
October 21st, 2010 11:47 AM #2
1. Yes. But there are better shops around than Rapide.
3. Check the level daily. I replace mine on a yearly basis.
2. Whatever the manual recommends.
4. Have your brakes cleaned.
- Oct 2010
- 59
- Nov 2002
- 36
October 22nd, 2010 10:04 AM #4
1. isang beses pa lang ako nakapag pa-change oil outside casa, ok naman, kahit sa gasoline station ok naman change oil and spark plugs as long as may oil filter sila para sa aveo hehe
2. honestly di ko nache-check hehe, umaasa na lang ako na iche-check ng casa yun every pms
3. bumili ako ac delco coolant dati sa rapide (ac delco din daw gamit sa casa e), gusto ko kasi dagdagan, pero once ko lang ginawa yun, tinatamad na rin ako mag check lagi hehe
4. parang normal naman yung grrrg sound pag incline kasi nahihirapan ung brakes sa weight nung sasakyan, may naririnig din akong ganyan pang magpa-park ako sa incline...pwede mo rin pa-bugahan ng hangin ung brake pads/rotor, baka sakaling mabawasan ung sound...pero kung pati sa patag/level roads ay may grinding sound pa rin, baka it's time to replace the brake pads..
- Oct 2010
- 59
October 22nd, 2010 10:37 PM #5thanks sir sa mga sagot.
pag incline lang yung "grrg" sound. sa patag wala namang sound. pinacheck ko na din naman yung brakes kanina. ayun, manipis na din yung brake pads. umorder na ko para mapapalitan.
may sa pa silang sinasuggest which is rephasing/refacing ng brake discs ba yun? di na daw kasi totally flat yung brake discs kaya dapat daw pantayin para totally smooth na ulit. sabi ko sa kanila magdedecide pa ako. ano sa tingin nyo mga sir? dapat ko bang iparephase/reface?
- Nov 2002
- 36
October 24th, 2010 07:50 PM #6
- Oct 2010
- 59
October 25th, 2010 01:43 AM #7
New app update for Gcash. It locks the Gcash account to the particular device you are using so you...
National ID Law
