Results 21 to 28 of 28
- Nov 2007
- 329
November 8th, 2008 11:09 PM #21OT: can all cars' ECUs be reprogrammed? and does the ECU also control the Aircon's compressor?
November 9th, 2008 02:05 PM #22
If the car is out of warranty, there's a fee. I don't know how much.
All cars can be "reflashed" if you have the right equipment. But it's mostly for things like fuel and ignition trim in the powertrain control module... I'm not sure, but I think the climate control works off a different ECU.
- Nov 2007
- 329
November 9th, 2008 02:23 PM #23oh okay. cool kasi kung controllable yung ECU na merong "tipid mode" and "nagmamadali mode". :p
- Dec 2008
- 1
December 8th, 2008 03:17 PM #24Greetings.
Nagtanong ako sa Gm shaw about reprogramming the ecu of my Optra 2004. Sabi sa service, they need to replace the spark plug ng pang 1.8 and then reprogram it. Tama po ba yung modification? they're also chraging me 2K for all that.
Thanks.
- Sep 2008
- 1,219
February 8th, 2009 10:29 PM #25pwede din kaya sa Mazda 3 itong reprogramming nato? ang lakas sa gas ng kotse ko e
February 9th, 2009 11:28 AM #26
Autotechnicka offers ECU reflashing. But it's expensive. About 30k pesos, last I heard. Re-tuning maps costs a lot. The difference with the Chevrolet program is that they have preset maps that they just flash into the car, so it's cheaper.
The advantage of the 30k reflash is that it'll optimize your economy and allow you to make a fair bit more power. The Unichip, which I have, does the same things, but it's a more difficult job, as it has to be wired into your car. Lots of Mazda3s running around on Unichip... makes lots more power, uses less gas. Lovely thing.
batangraon_14 never mentioned spark plugs... try going to North EDSA and getting a counter-quote. They might just be trying to make money off of you.
- Sep 2008
- 1,219
February 11th, 2009 10:42 AM #27Lots of Mazda3s running around on Unichip... makes lots more power, uses less gas. Lovely thing.
and where would be the most reasonable priced unichip being sold? thanks
- Dec 2010
- 11
January 12th, 2011 01:05 PM #28Good day! Jarhead, ano na balita sa optra mo nung pinareprogram mo? Maganda ba effect? Thanks!
Monk-owned R53
