Where is the best place to put the backup sensor display?
If possible, you can put it on top of the inside rear view mirror then run the wire up to the leading edge of the ceiling.
Or, at the base of the rear window glass, so you can see it from the rear view mirror or when you turn your head to look out the back window while reversing.
In my case, both options didn't work for the Jazz, Jimny, and Crosswind. So I just ended up putting the display on top of the steering column. That way I can easily mute the sound. I don't look at the display anyway.![]()
