Results 351 to 360 of 385
January 10th, 2022 10:45 AM #351
BANNED BANNED BANNED
- Aug 2021
- 132
January 10th, 2022 05:50 PM #352
January 10th, 2022 07:43 PM #353
Just an update ito yung stainless tirevalve ko na worth 130pesos s shop mismo binili, ang observe ko na kaibahan nya sa rubber is pag hinigpitan mo yung tpms sensor kahit dmo alalayan yung tirevalve ok sya matigas...
Sent from my Nokia 7 plus using Tsikot Forums mobile app
January 10th, 2022 08:05 PM #354
IIRC, Zeepin bro. Yes, Lazada.
4 external sensors and a receiver that is plugged into the cigarette lighter interface. The receiver displays the vehicle voltage, tyre pressure in psi or bar, the tyre temperature in degC or degF... It gives a soft(but high pitched) audible alarm if any of the tyre pressures is outside of your defined limits and if the vehicle voltage is below 12v or something...
Cost iirc was P1.5K to P1.8K...
January 25th, 2022 04:21 PM #355
How long does the battery in the sensor last? I bought my tpms last September 2021 just after a month the battery
of the f-r sensor already died. I replaced it with Panasonic cr1632 batt and just today wala na rin (3 months & 4 days).
Btw I already replaced also the battery of r-l and f-l sensor last Nov and Dec 2021. Ang natitirang original battery na lang
ay yung sa r-r sensor (going 4 months on Jan 28)
January 25th, 2022 08:01 PM #356
January 25th, 2022 09:20 PM #357
I have already replaced three of the valves in the ASX. Maybe the 4th one needs replacement anytime soon. Built-in yung TPMS ng ASX sa HU nya.
January 26th, 2022 09:23 AM #358
Ito ba yung mga sensors na naka-install sa loob ng rim? If so, how much did it cost you to replace one?
Sa MS ko, I was quoted Php9,000 for a single replacement. I said forget it and went aftermarket. No regrets ever since.
Kahit bagong external TPMS ang bibilhin ko taon taon, mura pa rin
January 26th, 2022 10:55 AM #359
January 26th, 2022 11:03 AM #360
