Results 1 to 4 of 4
- Feb 2006
- 15
August 22nd, 2006 06:22 PM #1i would like to ask if anyone from this forum knew the alarm wiring information of toyota townace noah prod. yr. 1996 from japan, bought from subic last Dec. and i want to install alarm/keyless entry. maraming salamat po...
August 23rd, 2006 02:53 PM #2
What alarm are you planning to install?
You don't need a wiring diagram if you will have an aftermarket (non-OEM) alarm installed. The installer will just test the wires to find out which is the right one.
AFAIK the ff have to be located:
*Always hot wire
*Ignition hot wire
*Door switch
*Door locks
*Parklight circuit
*Brake circuit (on some alarms)
*Starter wire (for starter kill)
A good shop can finish that in under 2 hours.
- Feb 2006
- 15
August 24th, 2006 08:55 AM #4
sa banawe, dun ka pagawa sa pinagbilhan mo ng alarm, alam na nilang gagawin...
pero, you will buy an additional central lock system...most of the time, pero some can connect it directly to your OEM central lock system...
