Results 1 to 14 of 14
    Apr 2008
    question lang po mga bossing! kasi ung power locks ko parang nagloloko na yata, pag auto lock ko e ayaw po, pero pag auto open naman e nagbubukas po. although 1 afternoon lng nangyari iyon (kasi ok na ulit) tanong ko sana kung may problema na kaya ung power locks ko?
    salamats!
    try to have it lubricated muna, baka stuck up lang.
    Apr 2008
    sir 1D4LV, stupid question lang po (baguhan lang) alin po nilulubricate yung mismong lock? kc sa naexperience ko, yung powerlock na nasa drivers door side un pinpindot ko, pag nakalock na oopen pero hindi ko mai lock ulit, den pag yung sa alarm naman (yung remote) pag pinindot ko yung alarm dapat mag lock sya pero hindi e... salamats!
    Jan 2008
    i had power locks installed sa car ko.
    this happened to me. culprit is a loose clamp.
    Oct 2007
    bro try mo check yung fuse ng alarm mo unlock - lock mo, kasi may fuse din yan.sir tanung lang po anu po ba alarm po niyo, OEM ba yung alarm niyo po o binili sa labas?
    kasi yung sa akin autopage rf315 yung fuse ang salarin ganyan na ganyan nangyari sa tsikot ko..baka makatulong lang!
    Apr 2008
    maybe you have a problem in your actuator. i think a replacement one costs around 250 petot. the OEM ones cost around a couple of thousands. so i suggest you go for the replacement. serves the same purpose.
    actuators can still be fixed. you just need to know where to have them done. replacements are cheap but per my experience, they don't last that long.
    Quote Originally Posted by markuz14 View Post
    just lubricate all moving parts by spraying them with silicon spray. Move it every now and then so the lubricant can penetrate the unreachable parts.
    after then see if it works. If it does not, then you may need to replace your actuator.
    start with simple solutions first para di mapamahal...
    Apr 2008
    * sir 1D4LV and moe, anu b ung actuator at OEM (sori po)?
    * sir EGcoolmhan, OEM (sa tingin ko OEM is ung Original Enhancements ng Car?... from Car company po?) po sya, TVS ba un (toyota vehicle security), kaso hindi p ako murunong tumingin ng fuse (he he... ogag!)
    * sir dok_nukem, mukhang mapapamahal ako pag nag change ng actuator (OEM kasi)
    pasensya n mga bossing, ngayon lang ako nagkasasakyan ng may ganito... pero salamat sa inputs!
    Apr 2008
    actuator is the mechanism which enables the doors to be opened remotely. normally, all 4 doors have actuators and when you press the unlock button on the remote (or central lock/unlock button driver's side) the 4 of them open simultaneously. OEM i believe means Original equipment manufacturer or something like that. i'd go for oem actuators, the taiwan made actuators didn't even last a year on my car. however, others claim that theirs lasted more than 4 years.
    Sep 2005
    Meron ba kayong ma-i-rekomenda na nag-aayos ng power locks? Driver's mano mano na eh.
    Makati lang o Mandaluyong.
    Buhayin ko lang ito. Can you guys recommend a good replacement for power locks. Yung tatagal naman ng two to three years
    May 2007
    Quote Originally Posted by edtf View Post
    buhayin ko lang....need one installed sa Lxi
power locks
