Results 11 to 20 of 24
November 15th, 2005 08:49 PM #12Originally Posted by umzzzzz
November 15th, 2005 08:51 PM #13Originally Posted by the_wildthing
change ko na lang sir yung whole car alarm system mukhang malayo po yang banawe sa amin eh.... thanks po ulit!
- May 2008
- 8
April 19th, 2011 11:21 AM #14Nasira yung central motor ng keyless entry door lock system ng car ko, saan ba nakakabili ng pamalit sa cetral motor ko ? pinagawa ko sya dati sa san juan pero sobra layo, accredited ng hyundai cars.
- May 2008
- 8
April 19th, 2011 11:25 AM #15Sabi ng electrician ko stcuk up yung central motor, kaya nung banklas , talagang stuck up.Sabi nya once makabili ako ng the same item, gagana uli yung keyless entry system ng door ko. Yung passenger doors wala namang problema dahil gumagana lahat sila except yung sakin driver's door.
April 19th, 2011 06:17 PM #16
Boss ano kaya problema ng remote ng alarm, mabilis mag drain ang battery sa remote, after replacing a new battery (model: 27A 12v alkaline) 2 days ma drain na ulit. Both remotes are having the same problem.. The alarm works fine if the battery is new. (after market alarm)..., It can be fixed? or I need to replace the whole alarm system again?
April 19th, 2011 09:04 PM #17
iba iba brands ba ng battery tinest mo? or kapag nagreplace ka same brand? nangyari na sa akin yan, although hindi sa alarm remote... may certain brand na mabilis madrain... tapos i switched to this brand eh ok na.
based on my experience, gp ultra maganda battery for alarm remote.
May 16th, 2011 08:55 AM #18
just wondering about these as on how safe is it our keyless entry alarm is?
what I just did on my cars is removed the power lock and just remained the alarm; since I did rather open the doors of my car by using a key for the automobile; it made me initiate on doing these as there are alot of videos in you tube on how to open a car on alarm/powerlock through the use of a mobile phone.
am just sharing these out as some point of time its also not convenient on removing the power lock as every time i step out the car I have to check on all doors if it has been lock from the inside already.
- Feb 2011
- 1
May 21st, 2011 03:21 PM #19Is there a way to know kung battery nga yung problema sa keyless remote? Yung akin kasi umiilaw pa yung LED ng remote pero hindi bumubukas yung locks.
- Aug 2009
- 46
May 22nd, 2011 12:46 AM #20Ilagay mo sa camera mode and cellphone mo, then iharap mo ang remote sa camera at pindutin mo ang remote.Tingnan mo sa screen ng cellphone kung may nakikita kang white light pag press ng remote button (not the led indicator). Pwede mo itong gawin kahit sa ibang infrared remote control.
