Page 1 of 2 12 LastLast
Results 1 to 20 of 24
    Mga bossing, ano po ba problem pag minsan eh di gumagana keyless entry ng oto ko, minsan kahit ilang beses ko nang pindutinyung button sa remote ayaw, tapos biglang omo ok.
    salamat
    Baka mahina na Baterya??
    Dec 2002
    most likely mahina na ang battery...
    pa check ko nga battery, mukhang duon mga eh, salamat sa feedback
    Mar 2003
    nangyari na sa kin yan with code alarm. it first started out like that then eventually ayaw na magbukas. pina check ko yun alarm and it was a busted chip. i suggest i-turn off muna yun alarm, then have your electricals checked muna as well as the alarm itself. mahirap kase mangyari kung biglang di mag-unlock mahirapan ka i-start sasakyan mo lalo na kung may immobilizer pa.
    Dalhin mo for check sa Winterpine, Araneta Ave.
    Happened to me once. Pinagpalit ko yun switch niya, since "I" lang ang usual na ginagamit kaysa sa "II". But check your battery first. :wink:
    Ayos na daw , mahina nga battery, thanks
    Mar 2005
    is there anyway we can substitute a remote once it's totally damage? yung spare ay wala na. so anong pwedeng gawin? replace the whole system? please help!
    Oct 2005
    Quote Originally Posted by bhongskie
    parang mas maganda kung palitan mo nlng ung whole system..or if the car is still under warranty, try mo ipaayos sa casa.
    Jan 2004
    Alam ko may shop sa banawe na nagdu-duplicate eh...
    Mar 2005
    Quote Originally Posted by umzzzzz
    car is under warranty but not the keyless, kasi pinakabit ko lang po iyon...sguro nga, palitan na lang ng bago, mas maganda cguro kung rubberize yung remote para kahit bumagsak ng bumagsak, eh hindi masisira yung chips sa loob unlike nung una kong nabili... thanks sir!
    Mar 2005
    Quote Originally Posted by the_wildthing
    change ko na lang sir yung whole car alarm system mukhang malayo po yang banawe sa amin eh.... thanks po ulit!
    May 2008
    Nasira yung central motor ng keyless entry door lock system ng car ko, saan ba nakakabili ng pamalit sa cetral motor ko ? pinagawa ko sya dati sa san juan pero sobra layo, accredited ng hyundai cars.
    May 2008
    Sabi ng electrician ko stcuk up yung central motor, kaya nung banklas , talagang stuck up.Sabi nya once makabili ako ng the same item, gagana uli yung keyless entry system ng door ko. Yung passenger doors wala namang problema dahil gumagana lahat sila except yung sakin driver's door.
    Mar 2011
    Boss ano kaya problema ng remote ng alarm, mabilis mag drain ang battery sa remote, after replacing a new battery (model: 27A 12v alkaline) 2 days ma drain na ulit. Both remotes are having the same problem.. The alarm works fine if the battery is new. (after market alarm)..., It can be fixed? or I need to replace the whole alarm system again?
    Quote Originally Posted by clinch_xtian View Post
    iba iba brands ba ng battery tinest mo? or kapag nagreplace ka same brand? nangyari na sa akin yan, although hindi sa alarm remote... may certain brand na mabilis madrain... tapos i switched to this brand eh ok na.
    based on my experience, gp ultra maganda battery for alarm remote.
    just wondering about these as on how safe is it our keyless entry alarm is?
    what I just did on my cars is removed the power lock and just remained the alarm; since I did rather open the doors of my car by using a key for the automobile; it made me initiate on doing these as there are alot of videos in you tube on how to open a car on alarm/powerlock through the use of a mobile phone.
    am just sharing these out as some point of time its also not convenient on removing the power lock as every time i step out the car I have to check on all doors if it has been lock from the inside already.
    Feb 2011
    Is there a way to know kung battery nga yung problema sa keyless remote? Yung akin kasi umiilaw pa yung LED ng remote pero hindi bumubukas yung locks.
    Aug 2009
    Quote Originally Posted by akosiboysen View Post
    Ilagay mo sa camera mode and cellphone mo, then iharap mo ang remote sa camera at pindutin mo ang remote.Tingnan mo sa screen ng cellphone kung may nakikita kang white light pag press ng remote button (not the led indicator). Pwede mo itong gawin kahit sa ibang infrared remote control.
Keyless entry problem
