Results 1 to 15 of 15
    Aug 2003
    car now has power lock, sensors, and alarm.
    but it doesn't have keyless entry, keyfob only has arm, and disarm.
    can i buy just the "keyless entry" , or whole set of alarm na dapat?
    next is,
    the automatic start,
    tell me if i got it right, so press the button, it will turn on the engine, ok lang nakabukas ang aircon?
    so, you can drive the car w/o the key? or it won't work? still needs the key?
    sensya newbie. sorry kung engot ang tanong.
    Aug 2005
    Mayroon akong dating ka opisina na mayroon remote start. If I remember correctly, kailangan na naka on ang aircon. Di ko lang maalala kung naka on din sa susian.
    Nag reremote start siya pag pauwi na sa opis. Para pagsakay nya malamig na ang car nya. Maghapon kasing nakabilad. Isang down side ay naka unlock na rin ang mga doors. So sa parking sa opis lang nya ginagawa.
    BTW, the car was a 2-door civic.
    Aug 2003
    yikes. walang option na ON ang engine and doors are locked? panget naman ng ganon...
    anyways thanks.
    i hope masagot yung ibang tanong. tnx tnx in advance.
    Quote Originally Posted by winferrer View Post
    next is,
    AFAIK, dapat yung whole system ang bibilin mo. ive never see na keyless lang ang benta sa banawe (or hindi lang ako naghahanap)
    Jul 2006
    next is,
    about sa keyless..... since may remote naman sya, pwede mong bilhan ng actuator. baka yun lang kulang or sira nyan.
    sa auto start naman. dapat talaga naka on ang aircon. if you install an alarm na may auto-start feature (like cobra). after 30 secs pa saka lang magbubukas aircon. so may delay sya. pero sarado pa din doors mo.
    then kung aalis ka na. i open mo yung door (by remote or susi). step on the breaks. then isaksak kaagad yung susi at ilagay sa on. kasi pag hindi mo ito ginawa mamamatay engine nung car. (anyway yung sakin kasi ganito sistema. i dont know sa ibang brand ng alarm)
    ang auto-start maganda sa matic kasi lagi lang ito naka park or neutral. pag kasi manual tranny mo at naka primera ka yari. hehehe
    Nov 2007
    Hindi pa rin ba available for diesel automatic ang auto start?
    Mar 2003
    tiboyx3m, dami na po auto start for diesel, meron na siya glow plug switch, which will wait until the heaters are done before mag autostart. with built in turbo timer pa. been using mine for 7 years now.
    about sa autostart na may naguunlock, yun yung mga alarm na nilagayan lang ng relay para mag auto start. ginamit lang nila yung extra channels sa remote, pwede mo ma accidental pindot habang nakastart na, and it will grind the the starter. isa pang di maganda is you have to press the button while listening to your engine kung naka start na, similar sa pag start ng kotse using the key, may mga alarms with built in autostart, these alarms offer better protection sa engine. no over cranking and it wont trigger autostart kung nakastart na. hiwalay ang start button, and pwede mo start without unlocking the doors. sa aircon pwede auto on, kaso lang kailangan mo autoclimate control. may sarili siyang trigger, since yung akin dial type, di ko pwede lagyan, i also have to leave it on para gumana.
    Jun 2007
    Quote Originally Posted by tiboyx3m View Post
    Sir tiboyx3m, I think available po ito locally. My strada, which is diesel-fed and with automatic tranny, is equipped with auto start as OEM. I'm not sure of the brand but it is marketed locally by Winterpine. You can inquire from their store if meron available for your car brand. I think their shop is along Araneta Ave, from E. Rodriguez going to SM Centerpoint.
    You can try this numbers to inquire:
    (02) 7164831
    (02) 7160049
    (02) 7164828
    Feb 2007
    You need to buy the whole alarm system para sa keyless entry plus actuators if your car is not yet equipped with power doors.
    Auto start is an add-on gadget to the alarm, cost around 1700 pesos (forgot the name of the autopage alarm distributor in del monte but they have this). You will use the same remote with the alarm using an unassigned button or combination of buttons. I not very sure but I think the car will start remotely but the doors will not unlock and the car wont run unless you insert the key. If you try to shift to drive without inserting the key the car's engine will die.
    About the aircon, I believe you must left if turned on.
    Jan 2008
    ka office ko may auto start, yung kanya bundled yung alarm, keyless entry and auto start...cant remember the brand lang...yung pinaka box ng system may mga settings ng delay sa aircon and doorlocks so kung normal na alarm system yang sayo at ayaw gumana mga locks...most probably sira ang actuators or talagang wala...
    Aug 2003
    very very informative!
    salamat!
    pakabit na ko mamya!
    will update..
    Jun 2007
    As far as I know, at least on my ride, once you enter your car after autostarting it, you should put in the key within 10 seconds, otherwise the engine will stop. I think this is a precaution to your car from being carnapped. So the answer to your question is, you may still need the key to drive it.
    sir post nyo naman kug magkano nagastos nyo saka anong brand... salamat.... balak ko din pakabit....
    Aug 2003
    200 lang ginastos ko.
    meh keyless pala talaga tong kotse. hehe..d ko man lang alam.
    natanggal lang daw yung cable ng actuator. kaya d gumagana.
    aion. labor lang binayad ko.
    i was suppose to buy the keyless entry alarm, 1800 lang ata. pero wala raw sensor. so i decided, pagawa na lang existing alarm ko. atleast original casa.
    d muna ko nagpakabit ng automatic start,
    my casa alarm was not capable daw,
    entire set,..they were selling it for 7500. new alarm, sensors, trunk, auto start, etc....
    d na ko nagpakabit, naisip ko, baka masira ko lang makina. starting it from afar. at magastos sa gas. naisip ko lang naman na benefit ng auto start is pag nasa mainit yung kotse, ma start agad. para pag dating ko dun, malamig na. but since i park naman lage sa carpark, o garage ng bahay. meh bubung naman. so no sense din. pero sayang, angas din sana. hehe...
    Nov 2007
    Quote Originally Posted by ooba99 View Post
    (02) 7164831
    (02) 7160049
    (02) 7164828
    Thank you so much guys for the quick replies.
    I guess I'm just not well informed about it. Btw, I already upgraded my alarm to Automate Pro GT 808 w/ TT, same company that manufactures autopage.
    Hope an auto start feature is available as an add on.
    Btw, I must admit, I want it just for porma.... nothing else.
