Results 1 to 6 of 6
- Jul 2010
- 570
January 7th, 2013 12:01 PM #1Just want to share my bad experience with HT-610 door lock controller.
Found ko kasi na puro sirang gear ang problem ng door lock actuator ko. Napansin ko na umiinit yun mga wiring at connector ng actuator at HT-610 connectors kapag nagluko ang HT-610. Hindi nga bumigay yun 15A na fuse. Dapat palitan ito ng 10A in case umulit problem.
So binaklas ko yun HT-610 door lock controller at nag in-circuit test ako. ok naman sa testing ko. Pero para sigurado ay ni-reverse engineer ko yun circuit sa pcb para maintindihan ko yun ko circuit. May mali pala nilagay na component na nag cause ng intermittent problem. Instead na 0.5 second ang driving ng actuator motor ay naging continuous ito at syempre bibigay yun mabubungi yun gear.
Ni-repair ko na lang yun HT-610. Baka same design din mabili ko uli. hindi naman pwedeng buksan yun bago at mawala yun warranty. At least sure na ko sa ginawa ko sa HT-610.
Kaya ko na post ito para maiwasan masunugan kayo ng electrical wiring, madalas ma drain yun car battery at madalas bumili ng door actuator.
- Jul 2010
- 570
January 8th, 2013 11:10 AM #2Picture of HT-610 Door Lock Controller
http://imageshack.us/photo/my-images...ontroller.jpg/
HT-610 will work normally upon installation. But after few months components inside the HT-610 will deteriorate due to wrong component layout. You will have intermittent lock/unlocking problem of car door. You will found out that gear of actuator will be broken due to intermittent continuous driving of its dc motor. Normally, door lock controller should turn on driving motor for half a second only to avoid damaged to actuator gear.
Just want to share to avoid car actuator damaged, electrical wiring overheating and possibly fire.
January 8th, 2013 05:00 PM #3
- Jul 2010
- 570
January 8th, 2013 10:19 PM #4Kahit anong sasakyan na wala pa central door lock ito naka-install. Depende din kung anong brand ma-install sa kotse. Malaman mo naman kung pumapalya na yun lock unlock at isa isa masisira yun mga 4 door actuator. Mapansin mo na puro bungi yun gear pag binaklas mo yun actuator.
- Jul 2010
- 570
January 9th, 2013 09:12 AM #5Actually. 2nd unit na ito ng HT-610 na-install sa kotse kasama ng car alarm. Yun 1st unit ay naninira din ng actuator at kaya pinalitan ay dahil burnt and melted na connector. Akala ko ay dahil sira yun switch sa main actuator. After reverse engineer ko yun circuit ng controller at understand ko na function each component. Yun pala switch sa loob ng actuator ( Door driver side ) for toggle of unlock and lock. Hindi pala ito limit switch to stop yun actuator motor.
Kapag nakita ninyo na may sign ng overheat yun connector ay same circuit din ito at baka iniba lang brand name. Dami kasi fake ngayun at copy lang.
Actually. Pwede ako mag manufacture nito na trouble free pa. Dahil nakita ko defect ng circuit at na-correct ko na ito. He he he.
- May 2011
- 191
April 23rd, 2013 07:50 PM #6Hmm good advice bro. A bit scary knowing that it could possibly cause fire. When dealing with locks I always call an emergency locksmiths greenwich because they know exactly what to do when it comes to locks. Get them to look inside and diagnose the problem if the owner/driver doesn't know how to.
How much usually is the dc motor?
