Results 291 to 300 of 345
July 11th, 2005 05:27 PM #291
nag-inquire ako sa honda cars manila, they are offering me code alarm (US) for 8K. and Titan alarm (Taiwan) for 6.5K. then i asked him kung pwede outside ng casa pakabit ng alarm, and kung ma-vo-void ng warranty, ang reply niya is: "ok lang."
so i guess magpapakit na lang kami sa autoline ng autopage alarm.
July 21st, 2005 07:54 AM #292
kunin mo compustar car alarm. I have it since last nov pa and happy with it. may remote start, paging system, two way remote with lcd, trunk button, may proximity sensor at marami pang iba. pinaka gusto ko yung may range na 1 1/4 mile.. kahit nasa bahay ka pagmay humawak sa oto mo maririnig mo sa remote mo. compustar.com
- Jun 2005
- 4
August 2nd, 2005 05:17 PM #295
basta wag kayo kukuha ng Alien alarm.. madaling masira yug remote nya.. tapos hard to find yung remote switch sa raon..
- Feb 2005
- 157
August 2nd, 2005 09:00 PM #296Originally Posted by revoGSX
August 2nd, 2005 09:04 PM #297
Originally Posted by vice
August 2nd, 2005 09:07 PM #298
Originally Posted by j_avonni
you can check if you have the "current sensor" feature, go inside the vehicle and set the alarm ON, open the dome light switch (minimal body movement to prevent the shock sensor from detecting it), pag nag-alarm, you have the "current sensor" feature.
- Mar 2004
- 98
August 13th, 2005 12:27 AM #299I have a problem with the alarm [Clifford(old Model)]installed in my vehicle. After disarming it, the engine wont start when i crank it. But after several attempt it will be ok. This happens intermittently. On other occasion its perfectly alright.
Sometimes at the gas station they ask you to turn off the engine, right? But as i restart the engine, same problem again.
Any ideas as to what the problem is?
Can you recommend a technician who is knowledgeable in alarm setups?
Thanks
August 13th, 2005 01:59 AM #300
tsong take it to any auto soound shops that install alarms baka may loose connection sa mga wirings. do you have remote start ba? kasi kung wala e I dont think na it will affect the starting of your ride.
repair kit lang. car care nut says, for toyotas, he recommends entire assembly replacement for...
rack and pinion repair
