Results 201 to 210 of 345
March 4th, 2004 01:35 AM #201
sir icon.. ano po brand ng alarm?
yung shock sensor adjustment po eh kadalasan wala sa main unit ng alarm.. external po sya na naka-plug lang sa main box.. try po ninyo sundan mga wires at baka makita ninyo...
March 6th, 2004 01:00 PM #202
Having problems Clifford alarms installed on Gen1 CR-V. After a few months the alarm would stop received trasmission from the remote after a few hours. Usually when you use it first thing in the morning or when going home from work. Installed Clifford Concept 100, then replaced with Clifford Arrow 3 (dealer installed). Same problem.
The Clifford Concept 100 was then installed (we installed it ourselves) on a 1997 Lancer with no problems so far. My friend is also having similar problems with his CR-V using a different brand car alarm.
Is there anyone else having the same problems with their alarms on CR-V? Which car alarms get along well with Gen1 CR-V? Or maybe the installer here in Davao does not know how to install properly?
March 8th, 2004 02:05 AM #203
i had avital alarm installed on our gen 1 crv way back 98. no problem so far, with autostart and remote rear window release. the problem i had was the driver side (non - oem) actuator, it was kinda hard to unlock because of the actuator . so i had a switch installed to aid in unlocking.
- Nov 2003
- 89
March 15th, 2004 12:34 AM #204Guys, m down to 2 choices na lang with regards sa alarm. ngatanong ako sa Evangeista last weeked ( I finally had the time to ask arnd) and it seems sa 3k budget ko d ako makakahanap so i raised my budget to 3.5K to 4K. nakita ko parang ok yung Venom Car alarm mura sya at ok naman features kaso yung isa ko pinagtanongan wala raw yun Trunk Release feature yun cobra raw ang Meron w/c is P400 higher ang Price. Ung isa naman shop wala raw trunk release yung mga yun AUTOPAGE raw meron. Any advice? you think mas ok kung sa Banawe na ako pumunta?
March 15th, 2004 08:34 AM #205
ize9
mag autopage ka na lang... at least hindi mahirap maghanap ng pyesa pag may nasira.Last edited by Supierreman; March 16th, 2004 at 01:26 AM.
March 15th, 2004 09:19 AM #206
Is there a way to have the alarm wired to the horns when it trips? Parang Ford Ranger kung baga... thanks.
- Nov 2003
- 89
March 15th, 2004 10:39 AM #207Supierreman,
Thanx for the feedback research ko nga ito. =)
Guys,
AUTOPAGE? ano ba mga features nito anyboby with experience or still uing this brand of alarm pa post naman po para may idea lang ako.
March 21st, 2004 08:13 PM #208
hi all,
will be getting a RAV4-SV within the week. since 2003 model siya, keyless entry lang. i'm planning to have an alarm installed.
some questions:
1. if i have an alarm installed, void ba ang warranty? if so, warranty for what parts?
2. meron daw available sa toyota makati, Code Alarm na 6,500. ok ba yun? reasonable price?
3. from the posts here, a lot of people recommend clifford, mannix or viper. pero maraming hi-tech features, most of which i don't understand or wouldn't know how to use. i don't want the autorstart feature, i just want an alarm which will keep my car safe. considering this, do i need the high-end kind like the clifford matrix or the mannix or viper 650vx?
3. is it safe to go to shops like autoline or intense? i'm not really a car buff so i don't frequent banawe or the makati shops. how long is the installation process usually?
thanks in advance for your feedback.
March 22nd, 2004 11:08 AM #209
additional question.
2 options na ang binibigay sa akin ng toyota:
1. code alarm - 6,500
2. autopage - 5,500
reasonable price na ba 'to?
March 22nd, 2004 11:33 AM #210
may waranty naman pag nagpagawa ka na sa isang shop.. so ok lang din kahit sa labas...
kaso you should find a reputable shop for the job
repair kit lang. car care nut says, for toyotas, he recommends entire assembly replacement for...
rack and pinion repair
