Quote Originally Posted by nicanjel View Post
Hi! We are trying to develop a security system for cars that will trigger its brake system composed of a disc brake that is connected to its master cylinder by a Brake Fluid line. We will attach an embedded device that is GSM capable so it can receive and read text messages. This embedded device is actually connected to a triggering device that is also connected to the brake system of the car.
The idea here is,.The owner will send a text message containing a special keyword to the mobile number of its automobile. Once the embedded device receives the message, it will check whether the keyword is correct. When it is correct, it will activate the triggering device to do something in its brake system to put the automobile on halt.
We need help, we will only be developing a prototype, but we need an emulation of the brake, or the actual brake system of a car. We need to consider the speed of the car while its running before the brake system can be activated for the safety of the driver. Anyone there who has an idea what's the best possible way to trigger the brake system of the car? And how can we test or consider the speed?
You'll need an electronic-activated linear-motion electric-solenoid for your system to activate the brakes. It can be patched into the existing brake system via the brake booster.
To consider the speed of the car, have the system apply the brakes slowly over a relatively long period before it completely locks the wheels, example: time from activation to full lock would be one minute. This would be enough to prevent accidents from happening.
But the system should also disable the ignition as well when the system as nearly locked the brakes. This should prevent the person driving the stolen car from doing the vehicle damage by forcing the engine to turn the brake locked wheels.
It's relatively a simple project. Digital trigger system to the solenoid control system and ignition kill system. It's also possible to have it trigger a GPS positioning system so you can find the car too.
