Results 11 to 16 of 16
- 63
November 18th, 2002 03:05 PM #11Originally Posted by OTEP
Sa itlog ba sa ilalim din ng tranny?
November 18th, 2002 03:38 PM #12
Nasa engine compartment po ang tranny ng Lancer, eh. Try looking for it there. Or, try following the wire that leads from the shifter para malaman niyo where it will end up.
September 29th, 2005 04:56 PM #13Originally Posted by OTEP
September 29th, 2005 05:53 PM #14
uy don't go under the car na naka-jack kasi delikado yan. nung nasa land rig pa ko yung isang motorman namin gumapang sa ilalim na naka-jack yung land cruiser. mataas clearance nun ha, kaso mas mataas tyan nya hehehehe! ayun awa ng diyos nya (indian e so di ko alam sino diyos nya) natumba yung jack, ipit tyan ni mokong. buti na lang madami kami nakakita naangat namin yung land cruiser by shear muscle power. skid marks lang inabot ng engot at puro taba e. pero sinabon ng husto ng toolpusher pagkatapos ehehehe! use a vehicle stand if you need to crawl under the car. and choke the wheels even if you have the hand brake on.
problem ko naman, meron ba nabibili na reverse light bulb na more than 55 watts? yun sa akin kasi stock 55 watts so nilagyan ko na ng fog lamps sa likod (parallel to the reverse light so they come on at the same time). e haba ng reverse ko sa driveway at pag umuulan madilim pa din. balak ko sana palitan yun bulb ng higher wattage, nagtanong na ko sa automotive hardware wala sila e.
September 30th, 2005 09:01 AM #15Originally Posted by yebo
Pilo, yung switch tanda ko medyo sa gilid ng tranny. Kung may voltmeter ka, mas ok kung i-test mo muna kung walang voltage sa fuse connections at bulb socket ... baka sa wiring kasi ang problema dahil na rin sa edad.
HTH
September 30th, 2005 09:36 AM #16Originally Posted by yebo
