Results 11 to 17 of 17
May 23rd, 2007 09:39 AM #11
*Toybeats: I do not have any tints on my windshield. It's just that I'm sufferring from poor night time visibility due to the degraded performance of my van's headlight.
*Mazdamazda: I know but don't worry, I seldom use the van at night and only use it during daytime.
May I ask if there are other "special" equipment or things needed to do prior installation of HID since i'm using an old school vehicle?
TIA
FrankDrebin GuestMay 23rd, 2007 09:39 AM #12
Yup. It is possible but it will also give you the same result when you upgrade it into a higher wattage bulb. Sayang lang. Ang problema kasi dito ay yung lens.
Here's cheaper solution
1. Replace the lens with a clear type ones.
2. Use an all-weather bulb. Install a relay or upgrade the wiring.Last edited by FrankDrebin; May 23rd, 2007 at 09:43 AM.
May 23rd, 2007 09:44 AM #13
May 23rd, 2007 10:58 AM #14
no offense po, but they are right about HID w/o projector type lamps.
indeed.
MABE you can improvise and fit your van with a light with projector lamp.
or MAYBE you can improvise and make a hole in your bumper, install a projector.
nakakasar din yung white bluish bulbs without HID peru always naka high.... dahil mahina sa kanilang panignin, peru sobrang liwanag sa incoming motorist.
May 23rd, 2007 11:59 AM #15
You could try changing your bulbs to Philips VisionPlus or Osram Silverstars. They're both stock wattage but their light throw's wider and farther. Just right for drivers with poor eyesight.
May 23rd, 2007 12:09 PM #16
are your headlights the same as the rectangular sealed beam types? if so then you can buy the semi-sealed beam clear types with h4 bulbs, ito sigurado tataas visibility mo as compared to old sealed beam lamps.
May 24th, 2007 06:44 AM #17
Or none of the above? We've had Ferraris and Lambos burn in SLEX and NLEX in the Philippines...
Hybrids and EV
