Results 1 to 6 of 6
November 14th, 2006 11:43 AM #1
master need your expertise on this.. im going to replace the headlight of my Honda Civic Esi 93... anong brand ang the best na ikabit.? and san maganda bumili.
i want the white one....
which is better the white or the blue one..medjo malabo na kasi mata ko
Thank you
November 18th, 2006 06:49 AM #2
November 18th, 2006 08:02 AM #3
go for yellow.
you'll regret the white or blue once you're in a downpour and with an asphalt road...the light won't be able to penetrate as much as the regular/yellow lights.
November 18th, 2006 11:33 AM #4
all weather or yellow since malabo mata mo.
next time, please use the search function. there have been scores of headlight threads/discussions already in the past.
November 18th, 2006 11:39 AM #5
yep. all-weather yellow is good. or, if you want, get an IPF 70/80W or 90/110W lamps- these won't a relay. but go higher than 90/110W you'll need one. anyways, have your headlight lenses cleaned too. para talagang maliwanag- saka kung buo ang tint nang windshield mo, pa-tanggal mo na yung 70% tira ka lang nang mga 7" sa upper portion.
November 18th, 2006 02:25 PM #6
You might need to have the socket replaced to "ceramic" types, if you plan to get high powered version.
Suzuki JIMNY [merged threads]
