Results 1,181 to 1,190 of 1387
November 16th, 2019 12:08 AM #1181
Ako naman low beam projectors lang ung ni-upgrade ko. Kept the high beam and foglamps stock. Actually I didnt feel that I needed the quad set up after the low beam upgrade since ok na siya for me.
And I also kept the high beams as stock lang para pag nagflash ako ng high beams, on na kaagad siya. Matagal pa din kasi start up ng hid kahit na sinabi nila na fast-start ung ballast. Hehe
- Jun 2016
- 67
- Dec 2013
- 146
November 16th, 2019 07:59 AM #1183
November 16th, 2019 11:17 PM #1184
Pag hiwalay ung low and high beam, di na ata kailangan ng harness CMIIW though.
Usually pag kit, complete na lahat.
- Jun 2016
- 67
November 16th, 2019 11:53 PM #1185
November 18th, 2019 10:50 AM #1186
good day mga sir. ask ko lang po. malaki ba ang difference ng stage1 (mini h1?) vs stage2 (d2s), in terms of output? and with regards po sa replacement ng bulbs to branded ones, alin ang mas ok sa dalawa?
i'm planning to push my retrofit with redline before this year ends, pinagpipilian ko lang if stage1 or 2. any inputs are highly appreciated. thanks!
November 19th, 2019 08:36 AM #1187
Depends on what type of mini h1 and d2s that they have. If he has the latest mini h1 (version 7 i think), then thats good na. Also it depends on your housing kung kasya ung stage 2 or not. Syempre if you have the budget, go with stage 2 na.
November 19th, 2019 09:33 AM #1188
*zechs
i'm not sure about the version of their mini h1, but for the stage2 its the nhk g5r, if that helps.
initially stage1 lang plano ko, but naisip ko mag stage2 na para atleast nasa mid level na and d2s bulbs na.
regarding the bulbs, choice of 4300k or 5500k. haven't decided yet, but i want a lower temp than the plug n play hid kit i'm currently using (6000k since 2010). ang hirap pag maulan lalo sa aspalto, good thing naka yellow fogs ako.
btw, car is honda civic ek.
November 19th, 2019 10:21 AM #1189
Malayo performance ng g5r sa mini h1. 4300k for oem hid look. If you want to upgrade to branded bulbs, get the philips extreme vision gen 2's. Pricey but sulit IMO.
November 19th, 2019 11:10 AM #1190
*zechs
thanks for the info sir. will go with the stage2 package na lang talaga. stick muna ko sa nhk bulbs na kasama sa package. upgrade na lang ako ng bulbs sa future if needed. thanks!
Discover the ultimate in relaxed romance with the best casual dating platform! Authentic Ladies ...
Exemplary Сasual Dating - Verified Damsels
