Results 1,341 to 1,350 of 1387
September 25th, 2020 09:41 PM #1341
- Oct 2009
- 152
September 26th, 2020 11:24 PM #1342
- Dec 2018
- 27
June 16th, 2021 02:53 PM #1343hello everyone, hope everyones doing good .
planning on getting hid retrofit by next month. innova 2017. Torn between stage 2 and 3. I have to admit wala ako idea about components but looks to me that stage 2 is almost like stage 3 except for the bulbs where stage 3 uses philips or osram na plus quality ballasts. is it worth the extra 4k to 7k to go get the stage 3 na? initially planning to get stage 2 kasi di naman ako madalas mag night drive pero baka kasi sulit naman pag matibay na bulbs ang nasa stage 3. Then palitan nalang ng Philips or Osram pag napundi na. Thanks
- Jun 2005
- 3,769
June 16th, 2021 10:49 PM #13442017 is the same body as the current model diba?
Bear in mind na retrofit for this model requires a lot of cutting ang breaking of housing. Hindi kasya yung base ng projector. Lalagyan ng additional bracket or papaliguan ng epoxy. Pag nagsawa na di mo na maibabalik sa original configuration. Replace headlight talaga. Also, may wire splicing involvedSent from my MI MAX 2 using Tsikot Forums mobile appLast edited by sirkosero; June 16th, 2021 at 10:51 PM.
- Dec 2018
- 27
June 17th, 2021 12:02 AM #1345Correct sir, same body ng current (2016-2021) models. Okay thanks for that info. I don't see that info elsewhere, i thought it is as simple as exchanging reflector bowls with 3" projector lens. Noted and thanks.
But assuming I am willing to take the risk. Do you think na sulit na ako sa option A? Stage 2, Hella G5 BRT, Heartray D2s. Hylux ballast
- Jun 2005
- 3,769
June 17th, 2021 08:39 AM #1346Was planning on getting mine retrofitted pero turned back dahil dyan. Hella g5 brt din.
The brands you mentioned are known sa retrofitters. Assuming orig nakuha mo, you cannot go wrong.Sent from my MI MAX 2 using Tsikot Forums mobile app
- Dec 2018
- 27
June 17th, 2021 08:50 AM #1347
- Jun 2011
- 1,076
June 17th, 2021 09:54 AM #1348Maganda bili ka ng DEPO headlight housings para dyan ikabit ang projectors.
Tago no ang stock OEM headlight housings para puwede ibalik sa future.
- Jun 2005
- 3,769
June 17th, 2021 10:18 AM #1349Di ko na tinuloy sa innova. Turned off ako dun sa part na kailangan basagin yung housing, unlike the usual headlights that uses h4 bulb na may projector na bolt on lang (like ng koito q5 sa vios ko) at di na kailangan basagin yung housing.
Thinking of having projector fogs instead Sent from my MI MAX 2 using Tsikot Forums mobile app
- Dec 2018
- 27
June 17th, 2021 03:30 PM #1350
Suzuki JIMNY [merged threads]
