Results 11 to 14 of 14
September 24th, 2005 05:22 AM #11
WD-40 on the edges and some yanking, then use the screwdriver as a lever to the screw mount to push out the assembly. You can also use a rubber grip (jar/bottle opener) with your other hand to pull it out at the same time. Good luck.
September 24th, 2005 05:31 AM #12Originally Posted by chris_d
kung sa palagay mo nasobrahan ka ng spray ng WD-40...
after mo nalinis or napalitan ng bulb ay Contact Cleaner naman apply mo sa socket or electrical wirings sa palagay mo inabot ng penetrating oil
kaya niya dry ang penetrating oil..
double check mo rin pala baka may clips or screw ka pa nakalimutan
- Jun 2004
- 1,311
- Jun 2004
- 1,311
September 24th, 2005 09:25 AM #14Finally natanggal ko na yung assembly! Kelangan lang pala na medyo mas malakas yung sampal sa kanya... hehe
One dude told me it was Li-Ion. Another dude corrected him. AFAIK the Zenix gets the Li-Ion hence...
MG4 EV Standard vs BYD Atto 3 Dynamic vs Toyota...
