Results 11 to 20 of 24
August 17th, 2007 08:43 PM #11
*mackkcam sir siguro yung nakasalubong mo naka HID yun or naka 100++ watts na yung bulb niya, pag naka 100++ watts bulb ka you need to replace the stock socket to ceramic para hindi masunog yung stock socket, plastic lang kasi ito
regarding dun sa crystal headlamp , anu po kailangan niyo yung stock o crystal? (yung clear talaga) kasi po sa evangelista maraming parts ng headlights e different model regarding po sa car niyo meron naman "siguro" niyan pero di ko po guaranteed na meron pero ok naman kung try niyo diba?
*mcbry bro Osram Hyper 80/85 nasa 480 each H4 (hi/lo) bro kayo nalang magusap nung nagbebenta pero madali lang naman install yan e
ito number niya 09185702232 MOND pangalan niya sabihin mo nirefer ni washburn, pero definitely kaya niya install ito free of charge! mabait kausap yan!
advice ko din po na magreplace ng cermaic sockets to play safe lang painstall mo narin sa kanya yun mga 150 pesos lang po yun 2 na!
HTH
August 18th, 2007 03:08 AM #12
August 18th, 2007 08:47 AM #13
evangelista is in makati not san juan. it runs almost parallel to the south super highway until arnaiz ave (pasay road).
August 18th, 2007 01:32 PM #14
mga magkanu kaya aabutin ng papalit? sabihin na nating Over wattage ung Bulbs ko for the headlight, isang palit lng ba ung plastic to Ceramic? i mean kahit mag palit pa ako ng mas mataas pa sa Currently kong i-install ngaun? ok lng xa? for example: 80/85 currently na papa-install ko ngaun, tpos sabihin na nating next year 100+ kahit di ko na palitan ung Ceramic Socket? magkanu pa paChange ng plastic na socket to Ceramic na SOkcet?
August 20th, 2007 03:07 PM #15
Why don't you put a lighter tint instead, for the safety of other drivers your overwattage lights might glare? Your increasing your light output may actually be doing them harm by glaring them and temporarily blinding them. This is more dangerous when people are crossing. Pedestrians cannot see because they rely on what is available; some cars have overpowering lights. Coupled with the heavy tint you might not be able to see them quicker. Finally think about this, you cannot see others as much due to the heavy tint, plus they cannot see you due to your higher wattage bulbs.
Don't forget to aim your lights properly too, sometimes it's just the little things.Last edited by mbeige; August 20th, 2007 at 03:09 PM.
- May 2007
- 37
August 20th, 2007 08:13 PM #16Washburn,
Sir tanong ko lang tungkol sa hyper na osram, recommended ba na to go for a higher wattage than 80/85? or stick to etong 80/85? kc mayroon ako na hid kaso sira na and i am planning to replace it with all weather. TIA
Josh
August 20th, 2007 10:23 PM #17
Hi Guys,
nadala ko na sa Tech ung sa Headlight ko and ang sabi nya is Ok pa naman daw ung Bulbs ko malakas pa ung buga, medyo may defect ng konti ung isa kong Headlight sa Kanan, prefer daw nya na palitan ko muna ung Buong Assembly before chaging the Bulbs,
Btw,
they say na mas Ok pa rin daw ung Stock na wattage ng Bulbs kesa sa Overwattage? ung sa Alternator ata ung nasabi nya dun eh... Tingin nyo, Any Comments on the side Effect of using Over wattage Bulbs, for ex. is 80++ watts?
August 21st, 2007 09:13 AM #18
Read all about it www.danielsternlighting.com
Going overwattage means you'll be taxing your alternator more than it was designed for. Upgrading the alternator, adding relays and higher gauge wiring usually helps.
August 22nd, 2007 01:12 PM #19
i agree with mbeige...one has to consider the safety aspects of making modifications in one's vehicle...safety to the owner of the car and safety to the people around
August 22nd, 2007 01:25 PM #20
+1.
People who misuse and abuse their driving lights (whether they are stock lamps, HIDs, or fog lamps) without regard for other motorists and pedestrians, I call them: Certified G.A.G.O. (Goons Aggressively Glaring Others).
Huwag maging G.A.G.O.; use your driving lights responsibly.Last edited by Bogeyman; August 22nd, 2007 at 01:30 PM.
Na lock ang Gcash ko, need verification pa and kasama sa list nila ang philsys ID paper, but when I...
National ID Law
