Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
    Jan 2004
    sir, naglagay ka ba ng relay para sa headlight mo?
    Mar 2004
    sir, pundi na naman ba yung ilaw mo ??? papalit ka na naman ??? baka naman di na kaya yung wattage ...
    Jan 2003
    baka na short lang.
    pagnababasa yung sa amin minsan, ndi umiilaw.
    Jan 2004
    dun papasok yung relay. i've ask auto electrician about that. pag di nga nilagyan, mas madali mapundi :D
    guys...check..always check your grounding....importante yan.di pwede ung naka ground lang sa may pintura na partng sasakyan.dapat sa bakal talaga.linisin niyo rin using sandpaper..tapos higpitan niyo.
    Aug 2003
    yung paj ko, napundi ang right headlight going on my 3rd bulb as compared to my left. With relay and wire harness na. After complaining to the car accessory where I always buy my stuff, they checked the wirings and they found out may crack ang relay ko, so may short somehow pag nabasa. After changing the relay, ok na ang bulb, di na napupundi. If either left or right seems to pop every so often, maybe di kaya ng wirings or existing electricals mo but if it is on a particular side always, then may problema that side, don't think it will be the bulb
madalas mapundi na head light
