Results 11 to 14 of 14
July 30th, 2012 12:03 AM #11
- Aug 2012
- 24
August 17th, 2012 08:13 PM #12di ako sure if H4 type na ba ang liteace or if converted to H4 with relay from previous Sealed Beam eto ay may mali sa wiring tantsa ko lang, kailangan mo etrace ang wire neto papuntang dashboard High beam indicator light, regarding sa Low Beam na naka ON kahit nakaHigh cguro sa setup mo nilagyan ng diode ang High switch papuntang Low Switch.... wa idea ako kung ano ginawa sa Headlight sytem mo... pwede mo elaborate kung ano ginawa mo bago nangyari to....
August 17th, 2012 08:24 PM #13
- Aug 2012
- 24
August 17th, 2012 08:48 PM #14ayun naayos na pala sir... heheheh...
kase naka DIY din ako from Sealed beam to H4 with relay kaya rewire yung Headlight sytem kasi parang nagdidim yung ilaw di ata kaya ng OEM switch contact at OEM wire,....
Kami dati naglalagay ng chain lock ng motor or bike. Iba nakita ko literal na kadena at padlock.
