Results 11 to 13 of 13
- Feb 2008
- 35
October 3rd, 2008 06:10 AM #11Mga bossing pasali naman. Before ko mabasa itong thread nagpakabit ako ng BLUE signal lights sa front. Hindi sya maliwanag so nagusggest yung suki kong shop sa banawe ng led lamp. Blue din yung nilagay nila at super liwanag. Satisfied na sana ako. Nung bumibyahe na ko ganun din nangyari like yung ke sagO pag turn ko ng signal mabilis din yung on and off nya pero nung try ko hazard normal yung blink nya. Since last year pa nangyari yung ke sagO baka me bago na po technology para maging normal blink nya. Just in case lang. Thanks.
October 3rd, 2008 09:07 AM #12
wala pa.. pansinin mo lahat ng bagong sasakyan, only the sidemarkers, park and brake lights are LEDs.
di pwede as main signal lights nga yun LED. wag mo din gaggamitin as reverse light kasi di yan mag-iiluminate ng road. pangit din LED as interior lighting kasi di nag-iiluminate ng maganda.
LEDs are good markers.. thats it. bright to look at, lower voltage, cooler operating temperatures...
alam ko lexus/infiniti has a big LED as headlights for their top end car.
- Feb 2008
- 35
October 3rd, 2008 07:37 PM #13Pasensya na po sa kulit I just chanced upon this from:
http://www.superbrightleds.com/tail-brake-turn.html
LOAD RESISTOR KITS
One LOAD Resistor is required for each turn signal bulb
6 Ohm, 50 Watt resistors can be connected across the turn signal bulbs to simulate the load of a regular filament bulb (2 Amp load). This will solve LED related turn signal problems such as hyper flashing or burnt out bulb indications. Resistor measures 1.96L x .64W x .60H inches, leads are 12 inches long.
Kit Includes gel filled moisture resistant splice taps.
CONNECTION INSTRUCTIONS: Using included splice taps, connect one wire to ground and the other wire to the turn/brake hot wire. Splice taps allow for installation without cutting your turn signal wires.
We also offer 25 Ohm, 25 Watt Load Resistor kits which can be used with LED side marker lights (194/168 type) to prevent bulb-out indicators from turning on.
Since you got this 2nd hand, its a good idea to change the drive belt (its cheap anyway). Also...
