Results 2,201 to 2,210 of 2382
July 9th, 2014 02:41 PM #2201
Hi Sir. Pa-pm naman ng retrofit quotations for Toyota Corollas '93 and 2014 models. Kailangan ba stock unit ang nakakabit? Ung '93 kasi namin is plastic na with moist na din. if you have also foglights for '93 models baka magpakabit na din kami. Thanks.
Posted via Tsikot Mobile App
- Dec 2002
- 2,335
July 9th, 2014 03:03 PM #2202
July 10th, 2014 12:18 PM #2203
Sir gary pa-pm po ang price yung parang hid set-up ng bmw para sa trailblazer. Ty po
- Dec 2002
- 2,335
July 10th, 2014 09:31 PM #2204Subaru Forester 2014 SJ daylight running lights
Aftermarket but oem quality. Double intensity output, auto ON, MAX output when engine ON> DRL function. LOWER output when you turn ON park lights, automatic. With 6 months warranty. after sales service available after warranty.
July 11th, 2014 06:21 AM #2205
Sir, i'm wondering kung nakapag clear lens swap ka na ng '14+ Sorento?
HID low beams with auto-levelling na kasi oto ko, but the fresnel lens makes a very fuzzy cutoff.
Iniisip ko lang what kind of clear lens ang pwede, kasya kaya sti-r or tsx-r lens, or maybe e55.
Thanks!
- Dec 2002
- 2,335
July 11th, 2014 08:05 PM #2207
- Dec 2002
- 2,335
July 12th, 2014 08:28 PM #2208Another Honda City GM retrofit.
Client wanted the LED bar on top with angel eyes. Not bad. Our aftermarket setup using OEM 3" projectors including ambient lighting with OEM leds.
- Dec 2002
- 2,335
- Dec 2002
- 2,335
July 19th, 2014 07:51 PM #2210Nissan Navara HID Projector Retrofit
We started this LED bar upgrades on automotive headlights and our aim is always to use this and have a result na hindi ricey. Meron headlights lang talaga babagayan and I think this one is a good example. We did a re- retrofit on this Navara coming in with a "bolt on setup" and customer was complaining about very poor output. The actual headlight shroud was touching and pushing the lens outwards. The last shop forced fitted the lens just to seal the HL again. What a horror story! The wiring layout is also a mess. We installed our aftermarket package with a new 5000k D2S bulb na aftermarket which is an alternative sa Osram CBI. Parklight and signal indicators function nung LED bar. We also installed our 70mm fog projector retrofit with vehicle specific brackets.
old ballast mounting
old bolt on projector, shroud was hitting the lens and previous shop had to forcibly pushed it together to reseal the whole thing.
Oh I see! That explains why the brembo pads seem to have a different design. The original Akebono...
Brake Pad Thread [Merged]
