Results 1,761 to 1,770 of 2382
April 21st, 2013 09:46 PM #1761
Bumper lights LED
We have the complete lighting upgrade for this vehicle. Projector retrofit for headlights, fog retrofit, DRLs, interior led lighting, LED tail lamps, LED lights bumper mounted.[/QUOTE]
sir gary sent you a pm.
- Dec 2002
- 2,335
April 24th, 2013 10:59 AM #1763Complete LED lighting for motorbikes, Denali D1 style
incl.
2" round or square 10w LEDs
brackets
waterproof switch
custom brackets
oem spec wiring harness
installation
installed on a Kawasaki Ninja 650
April 24th, 2013 05:28 PM #1764
Gary ako yun nagpagawa ng Rio HB sayo dati..
tanong ko lang sabi kasi sa site ni exled, DRL ready na daw yun headlamp assembly ng Rio HB
ito yun nakalagay sa site nila
Factory OEM Headlights for All New Pride (RIO,2011~) 5 Door
To use the eyeline as DRL (if you don't already have DRL's), you'd have to re-wire the parking light + wire to a 12V power source that comes on when the car is on and turns off when the car is off. Otherwise, you will have to cut the parking light + wire and connect it with your DRL + wire (if your car has the bulb type DRL). Which wire that is exactly, I'm not sure as I dont have your car in front of me."
TIA
- Dec 2002
- 2,335
April 25th, 2013 10:07 AM #1765
April 25th, 2013 12:08 PM #1766
- Dec 2002
- 2,335
April 26th, 2013 11:27 AM #1767
- Dec 2002
- 2,335
- Dec 2002
- 2,335
April 29th, 2013 04:22 PM #1769Another first for us:
Toyota Camry 2006 3.5V6
This car is equipped with oem hids with AFS (Adaptive Frontlighting Systems), i.e the projectors turn side to side when the car turns.
Why did the owner considered upgrading? after 6 years, the HID bulbs (Philips) are ready for replacement, so the owner opted for a complete upgrade of projectors and fog syst. The AFS system was maintained and everything is back to OEM
We have the complete projector upgrade for this vehicle including fogs with car specific brackets.
- Jun 2007
- 175
May 3rd, 2013 12:03 AM #1770hi Gary, have you done any CX5 retrofits? pictures naman if meron sana. Thanks! seriously considering it now.
you apply lang sa mga outlines at crevices ng emblem na may nanigas na dumi... ok na yan, make...
"Tamang OC lang" - a newbie's guide to car...
