Results 1,321 to 1,330 of 2382
- Nov 2008
- 46
June 27th, 2012 10:23 AM #1321good am sir gaganda ng gawa nyo meron po ba kayo para sa 2004 ford escape pa pm na lang po or any suggestions for the cosmesis of my escape black po pala escape ko thanks
- Sep 2008
- 581
June 27th, 2012 01:04 PM #1322
- Dec 2002
- 2,335
June 29th, 2012 12:45 AM #1323want to share many pix pero eto muna coz something out of the ordinary.
LED tail lamp retrofit for Subaru Impreza Sti 4 door, 2011
I did the 3rd brake light retrofit for this car already and the owner wanted leds also on the tail lamps. The OEM leds were retrofitted on aftermarket DEPO lamps from the U.S. Wala ata mahanap dito. 3 months in the making eto.
Each lamp is retrofitted with 8 leds, oem color with 2 intensities, park and brake output. The intensities were adjusted so that hindi naman nakakabulag.
I followed the C-pattern as some Subaru models have this arrangement sa tail lamps.
I also retrofitted 5 Philips LED sa side for visibility when coming out of corners. I've seen this in some BMW and Jaguar tail lamps.
Seen here:
I also retrofitted a led array sa lower part nung tail lamps to go ON when braking. Mas napapansin yung lights coming ON during braking vs. the leds increasing intensity although yung 8 leds will increase intensity during braking so best of both worlds eto.
Of course this can also be used together with the bumper rear fogs for more visibility instead of brake lamps.
Dito ikakabit:
Hope you guys like it
- Dec 2002
- 2,335
- Jun 2012
- 5
July 4th, 2012 05:33 PM #1326
- Dec 2002
- 2,335
BANNED BANNED BANNED
- Jul 2010
- 44
July 5th, 2012 11:10 PM #1328the bord can you recommend good place for aligning our projector headlights? i have a set of morimoto mini h1 and slightly off yung alignment. hirap humanap ng maluwag na flat area w/ big wall to aim it on. I read you need to back the car up about 25ft from the wall to have an accurate alignment. South area siguro baka may alam kayo Paranaque area ako e. Thanks!
- Dec 2005
- 4
July 6th, 2012 08:40 AM #1329Good Morning Sir Garyq! Great work po.
Sir pa pm naman po kung magkano ang cost ng retrofit sa AE101.
- Sep 2004
- 161
you apply lang sa mga outlines at crevices ng emblem na may nanigas na dumi... ok na yan, make...
"Tamang OC lang" - a newbie's guide to car...
