Results 1 to 7 of 7
- Nov 2008
- 14
March 22nd, 2009 09:21 PM #1mga sir need ko po yung opinion ninyo nagpakabit po kse ako ng hid s 94 corolla ko.tama po b kasi yung settings nya pag naka low ako yung white hid tapos pag naka high yung yellow.tapos napansin ko yung s likod ng headlamp hindi naka sealed dapat po b may mga goma un para hindi pasukin ng alikabok at lumabo yung headlight.need advice po.sa banaue po ako nagpakabit.
March 23rd, 2009 11:38 AM #2
your HID is HID high, Halogen low. it is cheaper and only uses one ballast each. it is not advisable to use both HID on low and high since it takes 5 or more secs to make a HID light on it's normal birghtness. in short, you can't flash your HID and it is also bad to flash HID lights...
I do hope you are conscious about your aim sir, kung marami po ang nag-fa-flash sa inyo, you might want to check if your low beam aim is good enough not to glare...
Tsikot Member Rank 3
- Jul 2004
- 1,540
March 23rd, 2009 10:21 PM #3Baliktad ata, white yung Low so I'm assuming ito yun HID then yellow ang High so ito yun Halogen.
Dapat may rubber seal yan, I'm sure na magmmoist yan and madudumihan
March 24th, 2009 12:34 AM #4
- Jul 2004
- 1,540
March 26th, 2009 02:54 AM #5
March 26th, 2009 10:16 AM #6
sa TS, pa post naman ng picture ng buga ng low at hi ng headlight mo against a wall.
July 9th, 2009 03:00 AM #7
well pwede din kasi may nilabas din ang manufacturer na high hid and low halogen pero hindi ito binebenta i think sa philippines
well single beam kasi yang bulb mo not telescopic, pag telescopic kasi covered yung butas sa rubber sa likod pero no prob naman yan wag lang mainit makina babasain mo or yung radiator mabasa while its hot kasi pag may usok papasok sa likod ng headlight moist yan.
ako kasi i put projectors na bolt on sa civic ko before butas din yung gitna ng rubber kasi walang bilog na nakabara wires lang nasa likod pero hindi naman nag moist. and sa hi ace ko naman h3 hid kinabit ko and may plastic cover yun pati sa crv ko may plastic cover yung likod di ko na kinabit kasi ayaw ko butasin hindi naman nagmomoist so far. siguro depende kung may init at lamig na hangin papasok sa likod yun mag moist
Kwento ng katrabaho ko, meron daw sya officemate dati na Italiano na tinanong daw bakit...
Traffic!
