Results 31 to 40 of 46
October 11th, 2003 04:45 PM #31
iceman sent you an email na. hope it helps also buy 4 bosch relay holders para u just plug in the relays into the holders after wiring and it also makes wring easier and avoid s loose contacts. use utilux terminals mas makapal kasi brass na gamit nila. hope my d-i-y project helps you to.
October 11th, 2003 04:54 PM #32
yup, thanks a lot and imagine this costs a lot less than buying those new tech bulbs, i'm currently using the bulbs na on stock wires and sockets, so far after driving at night i always check the sockets and i can still touch them with my bare fingers di naman umiinit and with this current set-up i can see better lalo na pag umuulan. I used to have those white bulbs na 60w rating pero 100w daw output, laki talaga ng difference, lalo na ciguro when i finish this DIY upgrade
- Aug 2003
- 107
October 11th, 2003 07:03 PM #33iceman and impulz ds2 ko sana i upgrade ung bulb ng revo ko. hirap kasi mgadrive sa NLEX pag gabi pag galing me sa scul lalo n pag umuulan sa NLEX grabe hirap mga drive. puede nyo ba me tulungan about sa upgrading ng headlights ko. kung puede give me some brands ng bulbs at wttage nito tnx. give nyo naman me na shops n pudeng kong puntahan. tnx
hope you help me guys.
October 13th, 2003 03:37 PM #34
iceman, jevy.
gamitin mo mga true rated bulds hindi yung mga bulbs claiming higher output at lower wattage inputs. osram, philips at flouser are good brands. as much as possible get the ones with the OEM color. yung mga white bulbs useless sa ulan.
jevy, ano klase revo mo? yung maganda yung headlite assembly or yung lower model na square ang headlite assembly. sa hiace ko, square yung headlite assembly what i did was to change that sealed beam assembly to Bosch bulb type asembly laki agad ng difference.
also try to check your headlite alinement. poor aiming of head lites results to poor visibility. kasi mali yung tinataman ng headlite beam.
- Aug 2003
- 49
October 14th, 2003 10:06 AM #35impulzz or Iceman.
pa-email din nung diagram na mas malaki sa gen_mheloy*yahoo.com
thanks in advance
October 16th, 2003 12:19 AM #37
mheloy,
ano ride mo? kasi yung diagram na binigay ko kay Iceman eh pang 97 lancer(pizza) kung itlog na lancer same setup rin. di ko sure sa ibang cars kung negative switching ang head lites so better have a tester para malaman mo kung negaive switching ang headlites ng ride mo.
October 16th, 2003 09:01 AM #39
impulzz,
yup, nagreply ako sa email mo so i guess di nakarating anyways thanks a big ;)
- Aug 2003
- 107
October 18th, 2003 01:44 AM #40impulz yung type ng headlite ko ay ung sa 98 model pa or yung unang unang model p ng revo n may kasama pang fog light. impulz ung bulb ko dati ay ung bosch na white 8 wtts galing un sa auction sa subic nakakabit sa pajero tinanggal ko lang at kinabit ko sa revo ko, kaso napundi kaagad ung isa. balak ko sana na palitan ung bulb at palitan na rin ung wires at lagyan ng relay kaso d ako marunong gumuwa nun. kung puede sana bigyan nyo ako ng shops n gumgawa nito?ask ko na rin ano ung pinaka d best n bulb at magkano? hope you will help me impulz.
tnx...................
peace!!!!!!!!!!!!11
Hybrids and EV
