Results 1 to 10 of 29
March 8th, 2007 02:54 PM #1
can't find thread na kakapost ko lang. nabura ata or di ko naipost ng tama
guys,
i just changed my stock headlight bulbs to philips vision plus. pinagawa ko sa blade (P899, free installation). i just want to ask if kailangan pang i-reaim yun? nagagalaw ba ang aiming simply by changing the bulbs?
thanks
March 8th, 2007 03:23 PM #2
for what car? usually, may screws that you can turn to adjust the aim of your bulbs just behind the headlight assembly.
March 8th, 2007 03:33 PM #3
*ssaloon
98 civic po. i was just wondering if simply changing the bulbs would be enough to misalign the aiming. kasi alam ko properly aligned yung stock bulbs ko. tapos siempre kapapalit lang
March 8th, 2007 03:38 PM #4
March 8th, 2007 03:44 PM #5
You can check to make sure they're both aligned right. At night, drive to a gas station and usually there's a wall. Face your car to the wall and drive in reverse until you are about 20feet from the wall. Check to see if your headlights are even. If you need to adjust..there's usually a screw that you can turn to adjust the headlights aim higher or lower.
March 8th, 2007 03:50 PM #6
http://hidtech.com/aiming.htm
Ito pala, that's where I remembered my info from
March 8th, 2007 03:52 PM #7
*xto
yep. happy ako sa pvp. maliwanag and farther ang abot ng ilaw
*kriskros
salamat sa link
March 16th, 2007 02:33 PM #8
btw, is philips vision plus considered "all-weather"? parang di ko nakikita sa mga thread.
March 21st, 2007 02:55 PM #9
repost ko lang yung tanong ko:
and i might add:
saan located yung pang-aim ng headlights ng civic 98? isa lang kasi nakikita ko. and i'm not sure if this is for up/down or left/right. napansin ko kasi medyo mababa yung right headlight ko (yung sa tapat ng passenger).
maraming salamat.
March 21st, 2007 03:08 PM #10is philips vision plus considered "all-weather"? parang di ko nakikita sa mga thread.
part siya ng osram silverstar, stock colored, 50% more throws kaya
medyo parang puti. btw pair na ba yung P899? osram siverstar ko
kasi P500*.
agree ako syo. battery dying will be the next owner's problem. kaso the only reason I'm buying...
All New Toyota Corolla Cross
