Results 1 to 6 of 6
November 15th, 2005 08:33 PM #1
guys need your info. i installed a new headlight bulb (Euroline) just yesterday, a few hours of using it i noticed that the left side headlight is dark while i was driving. i went down to see what the problem is. as i was looking at my headlight assembly, i noticed shrapnels of the bulb which exploded in my headlight assembly. ano kaya problem guys bakit pumutok yung bulb? yun lang naman sa left side...
jagxtrm GuestNovember 15th, 2005 08:57 PM #2
bka nahawakan mo yng bulb pre...
a small oil (from ur finger print) can cause a higher temperature on that area, thus causing the glass to 'crack' more easily...
o kaya naman natagtag yng bulb during shipment (from shop to ur home)...
pwede rin na may factory defect yng bulb...
November 15th, 2005 10:12 PM #4
korekek, nahawakan mo siguro yung glass ng bulb. or nasagi mo yung bulb sa gilid ng housing tapos basa pala o may oil/grease dun. very sensitive ang glass ng bulb kasi. any liquid film (water, body oil, grease, sweat, etc etc) causes uneven heating of the bulb surface. this in turn will cause it to crack or even explode. minutes lang yan sabog na. kaya nga it comes wrapped in a styrofoam protector and you're supposed to remove that only when about to install it. don't even remove it for 1 second until you're really about to install it. hirap na baka madisgrasya, bigla ka ubuhin at tamaan ng tilansik ng laway yung bulb.
one way to remedy pag nacontaminate yung bulb is to clean with contact cleaner or alcohol, but this is no guarantee. sometimes it works, sometimes it does not.
November 15th, 2005 10:25 PM #5Originally Posted by yebo
November 16th, 2005 01:36 PM #6
haaay... thanks for the info guys... di tuloy magkapareho ngayon ang headlight ko... anyway, i have to do with it for now, sayang naman kasi kung hindi ko gagamitin. thanks.
Burberry Men Leather Jacket oskarjacket
Verifpro - paypal, ebay, banks, crypto, docs and...
