Page 1 of 4 1234 LastLast
Results 1 to 10 of 35
    WHat do you recommend - best visibility h4?
    On stock wirings, Philips Vision Plus is okay...
    If you want more wattage then upgrade the wirings, sockets and relays so you can use a high wattage bulb (i.e. 90/100W).
    Been using Philips Vision Plus. Malakas buga.
    Sep 2005
    OT: mga sir, baka meron kayong DIY HID replacement? di ko kasi alam kung paano tanggalin yung stock, balak ko bumili either Philip Vision Plus or Osram All Weather. tia
    Quote Originally Posted by typhoon View Post
    Definitely agree... walang kuwenta ang 100/90... and all weather pa ito. Pricey ng lang ito. Sa Blade Php 899.75 ito pero sa ibang shops mas mura.
    How about osrams:
    super, super70, bilux, sylvania-silverstars, silverstars, all weather
    Sep 2005
    Quote Originally Posted by puroy View Post
    OT: mga sir, baka meron kayong DIY HID replacement? ...
    Re: OT: make sure that you are installing the HID in a Projector-Type headlamp assembly di tulad ng mga ogag na naglalagay ng HID sa pang-Halogen na headlamp assembly.
    You can get HIDs for about Php8k which includes the installation.
    Jul 2006
    The bulbs do not give the best visibility. The lens do.
    Bluish/white light is hard to see in the rain. Paalala ko lang.
    *russpogie - why in a projector headlight? diba dami nang installed sa mga h4/halogen headlight assembly?
    Sep 2005
    Quote Originally Posted by ineedmorehp View Post
    That's exactly my point. Halogen the headlamp assembly was designed primarily for HALOGEN lamps, nothing else. The projector type headlamp assembly was designed initially for Halogen lamps. The main difference is that the projector type gives the light source a cleaner and crisp projection of light and maintains the correct cut-off point on the beam so as not to blind other drivers on the road. The projector type headlamp assembly system is perfect for HIDs thus BMW and other premium car manucaturers use this headlamp assembly for HIDs.
headlight bulb
