Results 11 to 18 of 18
- Sep 2004
- 58
October 24th, 2007 03:55 AM #11Ganyan din problem ko sa Mazda Tribute, after installing IPF 100/90 H4 and wiring harness, both low and high beam is lit pag nilagay ko high beam.
Paano ba ma resolve to?
Thanks
October 24th, 2007 12:54 PM #12
^Check the wiring harness may mali sa connection mo. Standard headlamp systems will never allow this to happen unless modified like in overwattage headlight systems where additional wiring harnesses are added or beefed up.
October 24th, 2007 01:40 PM #13
baka naman may additional relay din yan...
in my case, I solved it by adding a peanut bulb in my stock headlight low beam connection. I'm still looking for a better solution though...
October 24th, 2007 02:35 PM #14
as i've recalled, it was an osram headlight relay kit with 2 pcs 30A relays with #12 or #14 sizedwires (i think) wrapped in a yellow rubberized tube (P900 bili ko noon).
nung pina-check ko sa electrician (after makabalik ako sa Manila noon), lagi daw merong +12V power doon sa OEM headlight socket low beam pag nag-switch on ng headlight di nya alam kung paano i-rewire yun sa kit kaya I ended up 'reusing' the kit para sa mitsuba & SNFL horns ko sa everest
October 24th, 2007 06:13 PM #15
sounds like same system I have.
one +12V will be always on, then two on/off switch - negatives. one for low, one for high.
however, if you only use a tester or hook a another relay. the low negative line will still remain running even when switched to high beam, unless you put a bulb. this is somekind of a sensor so the light indicator will show up in the dash too. the temporal solution is to put a small bulb like a peanut bulb so that the low negative will shut off once high beam is switched.Last edited by rion; October 24th, 2007 at 06:22 PM.
October 29th, 2007 01:11 AM #16
ganito setup ko sa city ko. look at my pic. narva super white bulbs 100/90 ceramic sockets ang upgraded relays and harness. tsaka ceramic fuse rin. kasi nag melt yung fuse casing noon.
so far ok naman. sarap pang biyahe sa madilim na lugar. naka try ako 10 mins on both hi and low. wala namang nangyari
of course, i only use it pag walang kasalubong. maganda din panglaban sa naka HID na iresponsable. isang pitik lang thats 380watts of light for you!
October 29th, 2007 01:06 PM #17
IN your avatar pic, what you have "on" are your headlights and "fog-lights".
What the thread starter is asking is if both LOW and HIGH BEAMS of the headlights are wired to turn on at the same time. Example, the hi-low filaments of the H4 bulb are both burning at the same time.
October 29th, 2007 06:47 PM #18IN your avatar pic, what you have "on" are your headlights and "fog-lights".
dont misunderstand me.
