Results 1 to 7 of 7
- Nov 2005
- 13
August 28th, 2007 04:03 PM #1Good day! my hid is working fine till i transfered it to my other car the driver side lights is permanently in high beam and at the other side is normal so when i drive, cars at the other side of the lane gets angry of my lights hope anyone can help thanks a lot!
August 28th, 2007 04:12 PM #2
Need more info. What cars did you transfer the HID's from/into? Are they aftermarket HID kits? Are you still using the reflectors for halogen bulbs? Did you mess up the wiring? A lot of info is missing...
- Nov 2005
- 13
August 28th, 2007 08:28 PM #3its installed in my accord but didnt use the high beam because its a separate hole, then transfered it to my pajero, they are aftermarket hid's, is the reflectors the one in the middle of the headlight? its still installed. i didnt installed it i have my electrician do it. thanks!
August 28th, 2007 09:23 PM #4
August 28th, 2007 11:52 PM #5
August 30th, 2007 02:55 AM #6
There are 2 types of HID kits in the market for bulb using both hi/low beam like the 9003/H4.
The first one uses HID for Low and High for halogen. You might want to check the wiring on the lamp that is always in hi beam.
The second one use Bi-Xenon which has a movable scoop on the bulb which changes position depending on whether it is used for hi or Low beam. Maybe the scoop is stuck on the hi position.
- Nov 2005
- 13
August 31st, 2007 06:11 PM #7thanks guys! im using h4, i dont know what type of hid it is, il just redo it with the electrician, hassle lang kasi it took so long to install then problems appear.
