Results 41 to 50 of 58
August 6th, 2009 09:27 AM #41
after almost a month, dumating na din ang araw ng aiming and fitting ng retrofit para ke precious. so eto na ang gattling gun shrouds fitted to my headlamps:
sad to say... hindi pwede sa akin ang shrouds na yan, so the e46 shrouds, or the one i posted before is the final layout.
and so, kanina, ginawa na namin ng kaklase ko ang aiming and alignment ng retrofit project namin.
August 6th, 2009 09:30 AM #42
here are some pictures...
aiming at the right hand lamp using 6000k d2s bulb:
the looks with the projectors on pero wala pang shrouds yan ah
this is the philips 4300k d2s bulb na gagamitin ko as my new bulbs
comparison of 6000k(left) and 4300k(right) hid
pasensya na kung may glare pa kasi alignment and aiming palang ang ginagawa namin dyan. wala pa yun shrouds at ang mounting ng projectors eh hindi pa fixed.
as of now, yun aiming and alignment eh natapos na namin. so, babalik pa ko ulit sa classmate ko for the wiring, mounting, and finalization ng retrofit project. as of now, lahat na ng mounting ng projectors are to be done permanently na ngayon. also yun paglalagay ng shrouds at yun pagsasara ng headlamps. narealize ko na mahirap pala ang retrofitting project, pero once it is done correctly, you will aprreciate it very very much.
all i can say, our retrofitting project is now 75% done... konti nalang at matatapos na din eto
August 7th, 2009 11:14 PM #44
test, pardon my ignorance pero tanong ko lang kung may function ang shroud?
August 7th, 2009 11:19 PM #45
thanks rion...
sq, sa nakikita ko oo. ang main function eh para matakpan ang assembly ng projectors. 2nd function, based sa nakita ko, eh tatakpan nya yun mga open parts ng projector kung saan pwede mag-escape ang light emitted
August 9th, 2009 11:39 PM #46
finally, natapos na din ang projector head lamps ko. i would like to share and present to you, gen 2 pajero projector head lamps
August 9th, 2009 11:43 PM #47
this is before, kung saan ang gamit pa eh ang oem headlamps with osram nightbreaker
note: this was taken at morning, habol lang kasi namin is the cut-off comparison
and eto na siya, gamit na ang retrofitted headlamps. infinity fx-r projectors with philips 81522+ d2s type bulbs at 4300k color temp
nag road test na ko kagabi at eto ang mga results niya
low beam at a. bonficaio during traffic
eto naman, para ma-test ko ang lapad ng bato ng projectors at low beam
at high beam
- Aug 2009
- 10
August 26th, 2009 12:59 PM #49nice choice of parts and clean set up sir! I was talking to Nighthawk about this before
where did you find the plastic headlights? we couldn't find one for a retro before and had to use the stock glass lenses.
August 26th, 2009 01:17 PM #50
sa banawe bri_g. matagal na kasi namin eto pinaguusapan ni nighthawk, as early as october last year. dun sa banawe, madami nagkalat na taiwan, pero i choose a china assembly
Thanks, will research more about it.
Traffic!
