Results 11 to 19 of 19
October 24th, 2007 02:27 AM #11
Your bulb capsule usually has quite a bit pressure inside(about 60 psi), so you must handle them carefully during installation. Your bulb sometimes are not operated at full output, this may cause the halogen cycle to stop allowing the bulb to BLACKEN and BURNS OUT quickly. In worst case a blackened bulb may soften and explode.
Some people doesnt know that fingerprints on the bulb can cause failure. I fact when oils from your skin gets hot, they cause the bulb to " devirity" or change from amorphous state into crystaline state called "lamp rupture". To prevent problem, do not touch the bulb w/ your bare hands. If you touch it clean it with soap and water or alcohol.
October 24th, 2007 12:52 PM #12
The fog lamp stock rating should be 55W for H3 bulbs, so it should not be too hot to handle especially the plastic lenses. If it is, it's made of substandard quality so do not expect a lot from it.
Tootsie has a good point, saan na-tap yung power source and grounded ba siya? Parang tricky itong problem kasi it only manifests itself after some time so it's not too much current or too much heat. Take the fog lamp assemblies out and see if there's anything wrong, craftmanship-wise or otherwise.
October 24th, 2007 01:53 PM #13
My guess would be the installation. hindi kaya maluwag yung socket/mounting? afaik too much vibration can damage your bulbs.
October 24th, 2007 03:08 PM #14
does the foglamp assembly have a heat exhaust tube? di kaya blocked?
November 6th, 2007 12:04 PM #15
Thanks for your inputs. Right now I'm leaning towards vibration and loose connections as the major cause of the problem. I already did some adjustments and hopefully put an end to the mystery.
Tsikot Member Rank 3
- Aug 2003
- 1,251
November 6th, 2007 11:47 PM #16I experienced short life span on my headlight bulb of my pajero before. Headlight yung akin ang problema, hindi yung foglamp bulbs. Eventually discovered that the relay case had a crack and was shorting on occasion. It wasn't obvious, and took me around 3 bulb changes before discovering it. Changed the relay and the problem went away.
November 7th, 2007 08:17 PM #17
November 7th, 2007 08:32 PM #18
Since nangitim ung dulo ng isang wire, you might want to upgrade the wirings of your fogs. Nangyari saken dati yan na talagang nasunog ung wiring dahil sa nipis ng nilagay.
Bago nasunog ng todo ung wiring, gumagana pa naman. Pero same case, minsan gumagana, minsan hindi. To the point na hindi na talaga at saka dun ko lang pinacheck. Luckily wiring lang ang nadali.
- Nov 2007
- 132
November 15th, 2007 09:21 PM #19From what I've read in this thread, I'm afraid my foglamps won't last very long. I just bought a cheap (under 1K) set of fog lamps today and had them installed. It works fine but i dunno for how long. It gets very hot quickly, so i guess the best thing for me to do is use them sparingly.
Daming issue ng SU7:grin:
Xiaomi E-Car
