Results 1 to 9 of 9
- 41
November 21st, 2002 12:59 PM #1bros
tulong naman dyan. my right fog light bulbs gets busted always. i have replaced my bulb thrice in 3 months. grrrabbbe orig naman yung fog lights ko, sa casa binili. kapag pinapalitan ko yung bulb parang may signs ng over-heating sa loob. need help!! nauubos pera ko sa h3 bulbs
November 21st, 2002 09:39 PM #2
otokoto,
Try o have the wiring of the right foglight assembly checked. Kung under warranty pa ang foglight assembly mo since sa casa mo ito binili then ibalik mo sa kanila to have it fixed. Di dapat madaling mapundi ang right foglight without affecting the other. Baka may short circuit sa right foglight wiring. Goodluck.
November 22nd, 2002 12:54 AM #3
otokoto::: anong klaseng foglight ito kapatid? ako dati nagkaroon ng problema sa headlight bulb dahil nag-vi-vibrate masyado yung headlight assembly. Baka ganun din yung problema nyan. :D
- 41
November 22nd, 2002 06:26 PM #4roydok
tnx I will have the wiring chek by tom.
pajerokid
baka nga sa vibration. check ko na rin
tnx sa inyong lahat
anymore help there guys???
November 22nd, 2002 08:49 PM #5
In addition to what the others mentioned, make sure also that no one touches the bulb glass with his hands.. this shortens the life of the bulb as well. Try to wipe it with alcohol and cotton before installing the bulb just to be sure.
November 24th, 2002 11:02 PM #6
dude...
baka masyado rin manipis ung wires na ginagamit mo for the actual wattage na nilalabas ng bulb......
- 41
November 26th, 2002 12:47 PM #7bros
mukhang susuko na ako dito sa foglights ko. i have all the things you have said bu to no avail. sawi pa rin ako. ang masama pa nito yung isa lang ang nasisira (passenger side).
may alam ba kayo na marunong gumawa o mag-repair ng foglights?:shock::shock::shock:
- Nov 2002
- 65
November 26th, 2002 05:21 PM #8Originally Posted by otokoto
June 15th, 2007 10:08 PM #9
buhayin ko uli ito OLD thread kasi ganito din sa kin, kaso driver side, stock mb100 fogs.. lahat nacheck na ng electrician pero ganun pa rin..
Yes Yes squeaking sound is heard when shifting only
