Results 11 to 14 of 14
- Sep 2004
- 58
July 29th, 2007 04:39 PM #11Bor asko ko lang did you just plug it directly? kasi I have the IPX 90/100W which was bought in Switzerland and it comes with an extra wiring (thicker wires) that have relay on it, and advise to install the wiring too along with the IPF.
The problem is when connected (Mazda Tribute), and switch to high beam, low beam light is also lit, which causes high temp on the headlamp unit. So far I just remove it na lang, though haven't tried it on different car brand.
July 29th, 2007 06:28 PM #12
I have thicker wires and relays installed to handle the higher current of the more powerful bulbs.
I suggest to have your headlight wiring checked. It might be a problem with the factory headlight relay switch system.
July 29th, 2007 07:21 PM #13
tama sila kung mag HID ka dapat naka projectors ka para naman di makasilaw sa kasalubong, sa H4 bulbs naman highly recommended ko OSRAM either silverstar o all weather
- May 2005
- 208
July 29th, 2007 08:23 PM #14ano hid gamit ng merc at ng bmw. parang yellow medyo may shade ng white
3M pa rin for me. I will only look at other brands if the quotation from the official distributor...
