Results 11 to 16 of 16
February 2nd, 2021 06:32 PM #11
- 52,731
February 2nd, 2021 06:44 PM #12try lazada.
try the folks who advertise replacement car headlight assemblies in the onlines. carousell...?
but my thoughts are,
if that headlight assembly does not have any electronics inside it,
and only the low beam bulbs are affected,
from what i understand,
most headlight assemblies are largely plastic and have no electrical conduction properties.
i do not see how replacing it will improve the bulb's performance.
mysterious.
sira na ba ang silverized reflector?
but even if it is,
that bulb should still glow normally and not be under-glowing, which is what i understand is your problem...Last edited by dr. d; February 2nd, 2021 at 07:19 PM.
- May 2014
- 1,318
February 2nd, 2021 07:49 PM #13Didn't expect that the end result is the headlight assembly itself to be the problem.
For a Nissan, if you can check global parts site like Nissan USA or Nissan JP or Nissan TH? But I also wouldn't get my hopes up that it is going to way cheaper if genuine Nissan part.
Reason is why is my Sylphy needed to have the aux fan replaced, I got quoted by Nissan around 18k php for the part alone. I tried checking outside and the only "cheaper" alternative was to buy from the states. But after doing conversion it came to still around 15k php, without shipping and any possible customs charges I may face. So I just did it via Nissan Casa.
For my rear suspension, there is a slight leak in the shock but there is still damping provided. But I wanted it quoted to find out. I think it would total 45k if done inside Nissan (exact php figure is a bit vague already). I had a trusted casa try to quote for me and told them to scour even OEM or compatible if they could find... answer was none. They quoted using genuine Nissan (no surplus then) and it would cost around 40k/42k php total if they did it. So negligible difference (Again a bit vague on the exact price now since it was over 2 years ago). Naturally, I did not have it done.
But good luck to you, hopefully makahanap ka ng surplus or alternative sources
EDIT: Try checking here if you can find the part number to compare the price.
2 15 Nissan Altima Parts, Accessories, and Merchandise - Nissan Parts & Accessories Online
I think it would be earlier than 2015 Altima in the states because we didn't get the refresh of it that generation before they stopped selling it here.
- 52,731
February 2nd, 2021 09:06 PM #14i googled nissanclub.com
it appears, you are not alone.
in post #27 of "headlights too dim? can't see! solution?",
it would seem, the silver reflectorized coating has degenerated.
amazon and ebay were mentioned as possible sources of replacement headlight housings...
google it, sir, for ideas.Last edited by dr. d; February 2nd, 2021 at 10:07 PM.
- Jun 2007
- 187
February 3rd, 2021 04:44 AM #15Projector retrofit might be the way to go. As long as the lens are clear.
Sent from my SHT-W09 using Tapatalk
- Jun 2011
- 1,080
February 3rd, 2021 07:56 AM #16Try mag-bakasakali sa Autospecs Banawe, mukhang may direct line sila sa local warehouse ng DEPO/TYC replacements.
Autospecs
Okay din ang suggestion na HID retrofit. Sa 20K budget may pasok na package iyan. At least 2X ang output at may minimum 1 year warranty. Dito ka sa 2 leading shops magpa estimate. Parehas maayos kausap.
The Retrofit Shop
Redline Auto Works (Detailing | Paint | Parts | Accessories)
Kung ako, sa HID route para hindi din sayang ang light assembly.
I guess SMC has been doing a good job selling them
Car Sales Data (2024)
