Originally Posted by
ronald_m
D2S bulb is specifically made for projector headlights.D2R bulb is design for headlight housing(e code) without projector.If compare these 2 bulbs side by side you'll see the difference.This is for OEM application.
Now if you're goin to retrofit a HID into a stock headight housing probably you need an adapter to fit your D2r or d2s bulb.Not really sure kasi di kopa na try tong route na to.
